13
29
burchfieldb
You may want to check your mounts for the IRS to see what your drive line angle will be. Mine was pointing down at .5 degrees towards the floor, which caused some issues. I ended up having to make custom bushings to fix the problem.
Thanks for the heads up. Haven’t ordered the engine yet so won’t be test fitting things beforehand though. However, doesn’t this get adjusted by spacing the tail of the transmission off the mount?
