Good luck with the complex stainless brake bends! If you’re not too far into it I’d switch to Ni-Copp, much easier to work with in all facets.
Stick with the stainless lines, you bought the good Ridgid bender so making complex bends that fall where you want is easy. Even I can do it. Did your bender come with the instructions? Feel free to reach out if you have any questions.
I milled a little slot in my 3/16" bender so I could make the bend closer to the end.
