Results 1 to 6 of 6
Thread: Pushbutton ignition wiring
    Senior Member Mbufford's Avatar
    May 2023
    Frisco, TX
    Hello FFR gurus.
    I’m going to be using two push buttons for my ignition system, one for ACC and one for Start. Please, spare me the comments about how using a key is easier—I don’t care and I don’t want a key.
    I’m trying to emulate the same basic switching functions of the standard ignition switch, but haven’t been able to locate any diagrams/schematics for the internal switching. So, I’ve been trying to reverse engineer it from taking readings from the kit-supplied switch. I think I’ve got this circuit set designed to act just like the stock switch, but wanted to get some other eyes on the circuit before I take the time to install it. First question: does this schematic accomplish the same/similar enough functions as the internals of the stock switch?
    I will be installing a coyote down the road, and as I understand it, the SMR (connected to EFI blue) and the Ignition relay trigger (connected to EFI orange) don’t need much current, as they’re just signal wires. With tha coyote setup, does the ignition switching actually need to be set up to cancel ACC during the start, like the stock switch does? My guess would be no, and that I can significantly simplify this circuit if I don’t need that switching.
    Thank you!
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: https://thefactoryfiveforum.com/show...n-North-Frisco
    Build videos: https://www.instagram.com/buffordmat...&utm_source=qr
    Senior Member Mike.Bray's Avatar
    Dec 2021
    Flower Mound TX
    Without giving it too much thought wouldn't you use a latching pushbutton to a relay(s) for your acc & ignition circuits? Them a momentary pushbutton for the starter solenoid.
    I really like these pushbuttons, they are very nice! https://billetautomotivebuttons.com/...billet-buttons
    My build thread https://thefactoryfiveforum.com/show...Roadster-Build
    Thread on Stainless Steel AN brake lines.
    Thread on fasteners and torque wrenches.
    May 2023
    Frisco, TX
    Quote Originally Posted by Mike.Bray View Post
    I got mine from Custom Billet Buttons. So far, I’ve been impressed with the quality. But yeah, I have a latching for ACC and a momentary for start. But, I’m not going to run the primary voltage through the switches—using them to control 40A relays is much safer.
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Mbufford View Post
    100%, the pushbuttons only control the coils of the relays.
    May 2018
    Milwaukee, WI
    I may be reading your schematic wrong but there appears to be one capability missing. You don't have an "accessories only" capability.
    The provided key has three outputs - IGN, ACC, and Starter. If you turn the key counterclockwise one notch from off only ACC will be powered constant with no power to IGN or Starter, if you turn the key one notch clockwise from off both the ACC and IGN are powered constant. Obviously two notches clockwise gives you ACC and IGN (constant) with Starter (Momentary).
    Not having an "accessories only" capability isn't the end of the world in these cars since we don't have many accessories (some don't have any at all), but if you are trying to replicate the key switch wholly or plan on having a radio, then I'd replace your top switch with a three position switch with Position 1 - OFF, Position 2 - ACC, and Position 3 - IGN and ACC. Of course you have a second switch (hopefully a momentarily pushbutton) for the starting process.
    BUILD THREAD: The Brew City Cobra
    Current Build: MK4 Complete Kit, Delivered December 2021; First Start November 9, 2022; Go-Cart November 23, 2022; Carbureted 427W, TKX, IRS
    May 2023
    Frisco, TX
    Yeah, I abandoned the ACC only early on in the thought exercise because I have zero accessories that would need to run independent of a started car.
