Originally Posted by
33fromSD
Also, if memory serves me correctly, depending if your using the headlights as DRL or not, if you are, you need to cut the tan wire going to the front headlights by the headlight switch connector and splice it to 12V. It's been 2-1/2 years since I wired mine but I recall having to do that.
Jim
I didn't go with the DRL and went with just the amber turn, and those work
