Results 1 to 9 of 9
Thread: firewall dress up ideas
    Jun 2021
    Good afternoon, all! hope your winters have been mild and/or natural disaster free...In NE Ohio, build season has begun! I am soliciting ideas for making the firewall look....well, not plain. I know powder coating is popular. I toyed with the idea of anodizing. Does anyone have a technique for the engine turned look?
    thank you!
    Tom
    Senior Member Mike.Bray's Avatar
    Dec 2021
    Flower Mound TX
    What if you took a piece of 1/4" or 3/8" aluminum, anodized it a color, and milled grooves with a ballnose endmill? You could then attach it to the standard firewall with acrylic adhesive, rivets, or screws.
    A little hard to see but like the firewall on this car.
    Or these valve covers.
    My build thread https://thefactoryfiveforum.com/show...Roadster-Build
    Thread on Stainless Steel AN brake lines.
    Thread on fasteners and torque wrenches.
    Senior Member MPTech's Avatar
    St. Louis, MO
    I liked the turned look, but my second choice was brushed aluminum look. I thoroughly sanded all of my panels in the engine bay, 320, 400, then 800 wet/dry, then carefully brushed them with scotch-brite pads for a grain look. Clean them well with lacquer thinner, then coated them with Shark-hide. This is time consuming, but I like the look clean & simple.
    I believe the forum Admin Polished his firewall, then added the turned look, but masked the stripes off. It looks AWESOME, but it was a LOT of work! But looks AMAZING!!!
    Quote Originally Posted by MPTech View Post
    Thanks for the Kudos!
    I built a jig I used to engine turn the firewall, upper and lower fan shrouds, dash and cubby walls of my brothers' build:
    They are labor intensive to create, but I do love the look!
  5. Likes MPTech liked this post
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Sometimes, just a good polish works! This is the forward firewall from FF Metal which is pushed forward about 2" and much more noticeable.
    Sep 2011
    Minneapolis, MN
    Silver Hammertone on this one. I eventually got a result I liked through the school of very hard knocks and a lot of rattle can paint. I'd just get it powder coated next time.
    Untitled by John Ibele, on Flickr
    May 2018
    Chaska, Minnesota
    I am also a fan of engine turning. I did this all in my garage with basic tools-a drill, some 2x4's and a sheet of old countertop. These are 1.5" diameter turns. After the firewall, dashboard, and door panels, my wife said "enough"!
    Image - 2023-06-11T095707.544.jpegImage - 2023-07-07T213226.594.jpegImage - 2023-08-21T204306.190.jpegImage - 2023-08-21T204312.797.jpegImage - 2024-02-27T175615.077.jpeg
  9. #8
    St. Louis, MO
    Quote Originally Posted by DanQ View Post
    Looks Great! I think firewall and dash/door panels are just enough! Nice touch
  10. #9
    Jun 2021
    Wow! Thanks for the great ideas. Some beautiful work here!
