0
5
looking good.
before you button up too much of the fuel tank, now's a good time to put in the "kleiner nut coupler mod" if you're going to do it.
the fuel tank prevents you from placing the PS lower bolt in place and might need to be dropped again to get the mod done.
Originally Posted by
egchewy79
looking good.
I'm glad you pointed that out! I looked at the mounting for the quick jack bolts last night, and was thinking there's not a lot of room there now....
I'll look up Jeff's solution.
I'm going with Jeff's mod. The only issue I've encountered today is finding a 7/16" bolt 1/2" long. Tried three hardware stores, and the best I could do was 3/4". I'm hoping that will do.....
