Likes Likes:  3
Results 1 to 6 of 6
Thread: Steering Rack Limiters
    Feb 2013
    I want to limit my steering rack travel a little. I've read various posts on using limiters. Some guys have said that they've had issues with using the Factory Ford limiters on the Flaming River racks. Is there another product that can be used?
    Glenn
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    For my ‘35 pickup…made my own as I only needed one for the passenger side of the rack. Why just one side is a long story….
    I used the grey plastic pipe fittings for larger diameter plastic hose. Can’t recall whether I was for 1-1/4” ID or 1-1/2” ID.
    Measured the required length, cut it, and then cut a section out lengthwise so it would just snap over the steering output shaft. Cost me about a dollar and a half and only took a few minutes.
    Pat
  3. Likes Tom Veale liked this post
    Jun 2018
    North Vancouver, BC, Canada
    Gen 1 '33 Hot Rod #1104
    Edmond, OK
    I used the spacers from Breeze - referenced above - for my rack from Flaming River. Worked fine.
    Feb 2013
    Thanks for the info. I'm installing front bike fenders and I ran into an issue of the fenders hitting the headlights when the tires were turned too far. Even without the fenders the tires come very close to the headlights. It stands to reason that it depends on what size tires are used on the front. My research revealed a lot of conflicting info on which limiters to use. It seems some builders had issues using the Ford factory limiters. I contacted Flaming River and they were very non-committal about any limiters. They seem to indicate that none were even needed. It looks like several have used the Breeze units with success. I'll do some more measuring to determine what I need.
    Thanks again.
    I raised my headlights because my front 315’s hit them, rather than limit the steering. It has the turning circle of a bus already
  8. Likes FF33rod, Just 1 More liked this post
