What are you guys doing as far as sealing the body close out panels for the interior?
This is the best picture that I have of the particular panel that I'm referring to.
The Bulb seal makes contact on the sides as you would expect. But the corners seem to leave at least a 1/4 gap. I'd really like to insure that this is sealed to prevent (as much as possible) heat, odors, and fumes from finding their way into the cockpit.
I am going to have to pull the lower side aluminum panels back out, in order to trim them a bit for the new seat belt brackets that I've just purchased, so now seems to be a great time to go back in and seal it all up.
Also...
Could someone post a picture that shows what the upper body close out panel should look like installed? I think I have an idea, just from trying different possibilities, but I'd really like to see a clear picture of it done right.
You're comments and/or ideas are appreciated!
As usual, Thank you.
The Stig
GTM #0081
