Thread: T5 vs S10 tail mounting
    Dec 2011
    I am changing from the standard ford tail housing to the S10 tailhousing and purchased a supposedly correct mount for the rear of the transmission. As you can see from the pictures, there's no way this mount is going in my car without something being modified. Do I have the right parts, or what did anyone else have to do to get this to work?IMG_3932a.JPGIMG_3935a.JPG
    San Carlos, CA
    Yes you will have to drill and slot the mount for the new tranny.
    Kirkland, WA
    So I used a hybird mount from Fortes and nothing needed to be drilled, it just fit, also make sure you chnage the pinion angle since the new mount is shorter and you will have issues. Here is pic of the mount that fits the frame mount on the FFR
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Dec 2011
    So I got the mount from Fortes. Mines red (see above photos) what is the spacing between the studs center to center on your trans mount from Fortes. Do you have a part number? I would love to bolt up and just add a spacer and go.
    Kirkland, WA
    Quote Originally Posted by R.T. Tavi View Post
    So the one I got from Fortes is http://www.fortesparts.com/product_i...roducts_id=197 here is a picture of mine next to the stock mount. You must have reveived the wrong mount.
    Tony Nadalin
    Senior Member tcoon's Avatar
    Angwin, CA
    I used the s10 pickup ball mount which has a single screw. just drill a hole in the cnter of your existing crossmember mount. note the s10 tailshaft is angled 10 degrees so you have to put some extra washers on one side to get the tranny level. we changed the rules last year to make this arrangement spec legal.
    Coyote powered Daytona Coupe Competition Racecar #21
    Challenge series #21
    FFR 33 Hot Rod
    2009 3rd place NorCal series
    2010 3rd place West Coast series
    2011 2nd place NorCal, 2nd place West Coast Series, 3rd place WERC class E1
    Angwin, CA
    i believe the mount was from a 92 or 93 s10 pickup and cost about 10 bucks. I have used it in my challenge car for 2 seasons including enduro racing without incident.
    FFR 33 Hot Rod
