Unused or upgraded parts
Wayne Presley Very Cool Parts Eight Stack Injection System for 351 .Package Includes Choice of Manifolds Throttle bodies. 50 mm velocity stacks, 60 Lbs injectors. Manifold choices are the stock style manifold Wayne offers or a custom Hogan Manifold that will fit any after market head offered for a 351 Windsor. 2000.00 for Wayne's manifold 3500.00 for the Hogan manifold .I will throw in the stock manifold if you buy the set up with the Hogan manifold. I will consider selling just the Hogan manifold for 1600.00.The Hogan manifold retails for 2800.00 alone.I also have a billet air cleaner setup that not only fits this set up but any Inglese system. 500.00
One NEW ED Curtis custom grind Solid Roller camshaft to match 8 stack System. 250.00
One advanced Auto parts 2 1/2 turn power steering rack new only used for mock up. 50.00
One new Edelbrock standard rotation water pump and front cover for 351 Windsor again new and used for mock up only .Was a birthday present from wife.110.00 for both.
One FF aluminum clutch quadrant adjuster and cable .75.00 For Wilwood pedal box .Maybe could be used with donor pedals but I don't know.
FF Rear lower control arms for three link. Make offer
Pictures of everything can be seen at HTTP://photobucket.com/anniversary-car.
The race car I work on recently picked up Hilborn Injection as a sponsor and made me an offer I could not refuse on a much bigger 8 stack setup and matching custom camshaft.
ALL PARTS DO NOT INCLUDE SHIPPING. All parts are new and never run they may have been installed for mock up buts that all.
Anniversary Special,Dart Aluminum 427, AFR 225 outlaw heads,Howard Cams,Hillborn stack injection,Liberty Gears prepedTKO600, Five Link, ISIS Wiring,8.98 @151 with no power adders Photo album
Can you tell me the specs on the cam shaft.
