Results 1 to 27 of 27
Thread: Custom 18 gallon aluminum fuel tank
Threaded View
    Member kabacj's Avatar
    Design goals:
    18 gallons in one tank for vehicle weight balance and simplicity of installation
    In tank fuel pump
    Use fuel safe fill plate so I can switch out the tank later for a fuel cell and keep all of my plumbing
    Sump system with trap door to drain the tank to the last drop
    I started the process making cardboard models
    Then I drew the cardboard models in google sketchup
    These were not big enough only around 12 gallons and did not have room for the fill plate
    I tried a few variations that would allow for filler and fuel sender using two locations
    Didn't like that and it was still too small
    Finally I had a design that fit with minor frame surgery, was big enough, and took the fill plate and looked nice. I find if it looks nice it often works well too. If it does not work well at least it looks nice. Ha!
    Time to start making parts
    First step was the top
    I am using a fill plate designed to connect to an internal bladder. I wanted to use all the same hardware with my bladder less tank
    To do this I needed to cut and weld in a ring to receive the fill plate bolts
    First I cut the top plate out
    I ended up using two pieces of 1/4 inch plate to make the ring because I had the smaller pieces laying around and I could make the ring with less waste.
    I welded up the ring and welded it to the top plate. Drilled it and tapped the holes for 1/4 -28
    Next I cut and bent the front sides and bottom
    The tank has 15 flat facets but is made from 5 plates. Top , bottom , two sides and the front.
    Boy was that a pain in the neck. The sides are like origami.
    The cardboard flexes and is much more forgiving then the aluminum. I ended up with more facets then planned .
    Finally I tacked it mostly together and ran out of argon.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
