Likes Likes:  4
Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 801 to 840 of 908
Thread: GTM roll cage modifications and race car build log
  1. #801
    Member kabacj's Avatar
    how did the paint job go? will I see it cruising around East Northport before it cools off?
    I gotta tell you. And you know me . I have no problem sinking tons of time in car. Bodywork takes FOREVER!!
    A few lessons learned.
    Lesson one. Painting a car that has been on the race track for 2 years is MUCH harder than painting your clean and un damaged body shell from factory five.
    WOW I did not realize how much that body had been abused. On the good side the fiberglass is over built and stands up to that type of punishment. On the bad side I had lots of scrapes and other damage from projectiles that really took a while to fix.
    Oh the fact that the car is covered in oil from its duty as a track weapon also makes things harder. Lots of cleaning before you even start working
    [URL=http://s1073.photobucket.com/user/kabacj/media/Factory%20Five%20GTM%20roll%20cage%20modifications/21BEBAC0-D561-412F-A5C2-1342BBA3E2BB_zpsouhmbfpf.jpg.html][/URL
    The body goes on and off lots and lots of times.
    Here is a mid work view of the body back on.
    After the body work phase then its the block and prime, block and prime, block and prime. Boy I did lots of sanding.. A good body buck is essential. I actually made this one a bit higher so I could spray under the rockers more easily.
    Did I mention that bodywork takes a long time!
    But to answer your question, YES! Absolutely I will be driving around town in the next few weeks. That's going to be weird but I cant wait!
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  2. #802
    Clarksville, MD
    John,
    Nice work. Only those that have done it themselves can appreciate the block and prime cycle. I can't say I miss those days! Looking forward to seeing the final result.
    And nice wedding tent!
    -Michael
  3. #803
    Quote Originally Posted by RumRunner View Post
    John,
    -Michael
    Hey Michael.
    Yeah I got the idea from you regarding the wedding tent spray booth.
    It worked very well.
    For 200 bucks on Amazon you get a 10x 20 tent. Sure it's not made for a lifetime of use, but it will last a week while you paint. Mine was up in high winds 20 mph and survived. They say it's not made for greater than 10 mph. I agree it's lightweight.
    I hung fluorescent lights along the side so I had reasonable light. I even did some painting at night.
    Finally I setup the tent with two 20 inch box fans blowing air in instead of blowing air out.
    The fans were filtered and aimed up toward the roof of the tent. The air blowing in didn't disturb spraying in the tent but also had the benefit of keeping the tent walls flexed out Air escaped from under the tent sides. Sorta down draft!
    This setup didn't work as well when winds were over 10mph. But in light wind it was great. Very little dust fell into the paint.
    XTF #2
    GTM # 344
  4. #804
    One of the things I wanted to do before I painted the car was flare the front fenders over the 295 front tires.
    My goal was to improve the aero on the car over my hacked up wheel openings and hopefully make the wheel arches look like they came like that from factory five.
    This job turned out to be way more work than I planned. Matching the lines on the car and making everything symmetrical is not easy. Especially when you are building into thin air (no reference points like you would have if you were repairing a fender.
    On the good side I got lots of practice laying down body filler and sanding it off.
    My other goal as to keep the fenders the stock 1/8 to 1/4 inch finished thickness. Mostly fiberglass cloth with a thin layer of filler over top
    Strength is not an issue below 1/8 inch but rocks are surely going to spiderweb the paint above if you go any thinner.
    With slick tires the wheel wells take tons of punishment. Unless you design a double wall wheel well or don't mind ruined paint you need to keep the fenders at Rock proof thickness.
    Here is a picture of the work in progress. Note where I cut through the gel coat. Beware you are entering pinhole hell as soon as you do this.
    XTF #2
    GTM # 344
  5. #805
    Clarksville, MD
    Quote Originally Posted by kabacj View Post
    John,
    To prevent the spiderwebs, I lined the inside of each wheel well with 1/4" dynaliner. It's closed cell foam so it doesn't hold moisture, provides enough cushioning to minimize any damage from rocks, inexpensive for what it protects, easy to apply, and so far has held up very well.
    -Michael
  6. #806
    John,
    To prevent the spiderwebs, I lined the inside of each wheel well with 1/4" dynamat. It's closed cell foam so it doesn't hold moisture, provides enough cushioning to minimize any damage from rocks, inexpensive for what it protects, easy to apply, and so far has held up very well.
    -Michael
    Very good idea Michael. After 2 years I did not have any issues with the stock hood, however I would love to make an ultra thin lightweight version for the track. Dynamat is a great way to protect thin fiberglass
    XTF #2
    GTM # 344
  7. #807
    San Diego
    The pin holes are nothing a good primer will not take care of.
    Looking at your pictures it looks really nice to have such tight wheel openings, but have you jacked up the car and tried to change a tire? Looks like it might become a chore once the suspension drops.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  8. #808
    Senior Member mikespms's Avatar
    North Miami,FL
    Hey John,
    Nice work, glass and body work is time consuming and tedious. For the pin holes l recommend duratec primer sealer, it is like gel coat easy to sand and will prevent sand marks and lifting. Fo the wheel wells a good heavy coat of spay on urathane truck bed liner will do the job and is a lot lighter than the dynamat.
  9. #809
    Good point Crash but with the hood tilted up the front tires are far from the wheel arches. I usually jack from the front under the corner of the hood as my light weight jack is not low enough to fit under the car.
    No clearance issues. Maybe if I use the low profile jack behind the front tire with the hood closed it would be a problem. Ill check, but I'm not doing nascar style pit stops so popping the hood works.
    XTF #2
    GTM # 344
  10. #810
    Clarksville, MD
    Quote Originally Posted by mikespms View Post
    Hey John,
    Whoops! I meant DynaLiner - not the sticky asphalty dynamat! The dynaliner is very lightweight.
    Thanks for the catch!
    -Michael
  11. #811
    Hey John,
    Yep Mike, I agree the Duratec is great stuff. It filled many holes, but some needed a follow up pass with glazing putty to fill.
    I'm trying the truck bed liner on my aluminum close off panels. Traditional 3m rubberized under coat was rock blasted right off.
    XTF #2
    GTM # 344
  12. #812
    Houston TX
    I used truck bed liner as well with good results so far.
  13. #813
    Quote Originally Posted by Fraser D View Post
    Good news Dave. I think truck be liner is the hot ticket.
    XTF #2
    GTM # 344
  14. #814
    Once the front was done I began prepping the roof and thinking about installing my modified roof scoop.
    As I'm sanding away the layers of hot rod black on top of a coat of epoxy primer I remember the research i did on NACA ducts.
    Back in the late 40s the Air force was developing jets. The engines were not very powerful so the aircraft designs attempted to be as low drag as possible.
    One of the ideas they had was to submerge the intakes with the aircraft exterior instead of sticking a high drag scoop up into the airstream
    Lots of information on the Internet on how they work. Seemed perfect for my application. Low drag and since I don't need positive pressure seems perfect.
    The design creates vortices that deflect air into the inlet.
    Since I was creating tons of dust on the roof I was able to see it work as I blasted air over the roof I could see the vortices form and the air dive down into the inlet.
    Cool!
    A little foam and fiberglass and I had a NACA duct on my roof.
    XTF #2
    GTM # 344
  15. #815
    That's pretty cool. Do you think that it will create more or less wind noise, cut in this fashion, compared to the standard roof scoop sold for the kit?
  16. #816
    Quote Originally Posted by Aceflo View Post
    Hi Aceflo
    Which intake will make more noise? Good question.
    I think I depends a lot on how fast you are going and how you mount the intake.
    Noise comes from turbulence. To the extent that you are creating turbulent air you will hear it.
    The NACA duct is all about creating vortices. How loud are they? No idea.
    the roof scoop offer very little turbulence if it is only cosmetic. (No flow through) If you plan to allow air into the engine compartment how you do that will determine how much wind noise is generated.
    My original plan was to first create a smooth duct into the engine compartment you can see here.
    Then install a modified version of the stock duct. My modification included smoothing out the air path through the stock duct by building up the air path with foam and covering with fiberglass.
    Not sure which would produce more wind noise. I think this is the kind of thing you would need to test.
    All that said there are many many things you can do to your GTM far more easily like sealing the passenger compartment that will quiet your GTM down.
    Production cars are so tight they install vents in the car so you can close the doors else the airlock would bounce the door open as well as make your ears pop when you slam the door.
    Those vents are specially designed to allow air out but not sound in.. yes I did lots of research on this too
    XTF #2
    GTM # 344
  17. #817
    In so after all the research on drag and airflow I ended up using the NACA duct as both a drag reduction measure and design element.
    I love when the same thing serves multiple purposes.
    XTF #2
    GTM # 344
  18. #818
    Clarksville, MD
    John,
    That shot looks absolutely fantastic! If the rest of your car looks half as good as that, it's a stunner! The red stripe along the top of the duct is a great design element. Well done.
    -Michael
  19. #819
    Thanks John. I'm super interested in what you discover in regards to the noise that it produces.
    I definitely will be using a roof scoop of some variation, and I really like your idea here. It looks great.
  20. #820
    Houston TX
    Very nice John!
    So she is white now?
  21. #821
    Very nice John!
    Yes sir. My street vehicles have only ever been black. Track vehicles have been many colors, so since the GTM is mostly track I figured I would make an exception to the black rule.
    Hi Aceflo. Here are some pictures of the mods I did to the stock scoop.
    from the bottom you can see I created a smooth (but not finished yet) air path that matched the cut out on the roof.
    and from the front view I smoothed the transitions to that air path.
    My goal was lower drag, but it turns out that turbulence causes drag but also sound. So we are looking to eliminate the same thing.
    John,
    -Michael
    Thanks Michael. I was thinking about the livery while I was sanding for several days and the intake and graphics sorta came together in an idea for a livery.
    XTF #2
    GTM # 344
  22. #822
    After burning in the midnight oil for two weeks. Guess what shows up! The mother ship.
    It was great to see Scott again. Scott is the expert driver of the Factory five transporter.
    And away she goes off to SEMA.
    XTF #2
    GTM # 344
  23. #823
    Here we are at the show.
    XTF #2
    GTM # 344
  24. #824
    Houston TX
    Congratulations John!!!
  25. #825
    Member claybags's Avatar
    rio rico,az
    John, that is totally outstanding!!
    GTM 422, LS6, cam, heads, Mendeola trans
  26. #826
    San Diego
    Kinda surprised that FFR put your car in its booth after the significant nose change. They always told us that they wanted the body to stay as close to what they offered out of the mold as possible. It looks good, I'm just a little surprised. Maybe FFR will finally embrace the significant changes I have made? Yeah, probably not.
    Enjoy the show. Wish I could have made it out there this year.
    www.myraceshop.com
    GTM solution kits
  27. #827
    Yeah only GTM people notice. It's a GTM race car after all so I guess that allows some leeway for modifications
    XTF #2
    GTM # 344
  28. #828
    I like what you did with the Factory Five Badge and the stripe. Pretty cool looking.
  29. #829
    Clarksville, MD
    John,
    Simply stunning! Congratulations!
    --Michael
  30. #830
    Thanks man.
    Here is a close up.
    XTF #2
    GTM # 344
  31. #831
    Thanks Michael
    I'm happy with how it turned out
    XTF #2
    GTM # 344
  32. #832
    Catonsville, Maryland
    John now that looks fantastic. You are proving that you are a component car renaissance man\GTM Whisper
  33. #833
    Quote Originally Posted by Presto51 View Post
    Haha
    So in with the emblem I wanted it to fit tightly and flush to the surrounding body.
    It's impossible for Favtory Five to mold the impression for the emblem that shape as the edges would not have any draft angle to release from the mold.
    So to get the sharp 90 degree edges I wanted I first filled the outside of the impression with fiber reenforced filler.
    Then I cut a wooden puck slightly larger then the emblem.
    I covered the puck with 80 grit paper and mounted the puck on a hole saw mandrel.
    Then proceeded to cut a nice square edged impression for the emblem.
    Worked very well.
    XTF #2
    GTM # 344
  34. #834
    So John .... where did you get the idea to do the emblem/stripe?
    Out of all the details about the car, the emblem work really differentiates between good and great work. It's the fine details that count, and some ideas that I have seen from your build really surprise me. I would find myself hard pressed to think .... "hey, that emblem doesn't quite look right. Let's change how it sits on the car, and then accent it with a stripe to top it off".
    So do you wake up in the middle of the night, from a dead sleep, and say "Hey! Let's cut the nose off the car and reshape my own!"?
  35. #835
    So John .... where did you get the idea to do the emblem"hey, that emblem doesn't quite look right. Let's change how it sits on the car, and then accent it with a stripe to top it off".
    Thank you sir.
    The GTM body was made to be mass produced. I Just change it to how I think you would make it if you only needed to make one.
    While I was sanding for hours the design just came to me. I like it, People seem to like it. I'm happy with that
    john
    XTF #2
    GTM # 344
  36. #836
    LCD Gauges's Avatar
    Toronto, Ontario
    Insane conversion from the last time I checked in! The paint theme looks great!
  37. #837
    North Miami,FL
    Haha
    Worked very well.
    Hey John,
    Congratulations! That's what I call kicking ***,knocking out the bodywork and paint in short order with great results.
    I used the same technique to flush mount my gas caps.
    Now for some action shots and updates on your mechanical upgrades and trans,Again well done!
  38. #838
    Charlotte, NC
    John, That is an awesome picture. I love the ITB intakes. (Hillborn?) I know that you've set this up for race only, but could something like that work well for street? I know that it isn't necessary for street applications, but it just completely "makes" the look of the car from the rear.
    Great job with the body. The whole car looks great. Congrats!
    The Stig
    GTM #0081
  39. #839
    Great work! I love the way the stripe ties into the scoop.
  40. #840
    I cant believe the transporter and probably the 818c was 2 minutes away. I wish I had known! but I'm guessing you had to keep it under wraps.
    Congrats on a beautiful job well done. I imagine few would suspect that that was a driveway paint job!
