0
0
Here is another interesting part.
One of the upgrades I am planning for my 818 is a pedal set with a balance beam and adjuster. The 818R has a Wilwood pedal set, though if you watch carefully halfway from the track test video the adjuster knob was removed from the dash (curious). This lets you dial the front rear bias for street and for track. Whatever the WRX bias is is likely not right for the 818. I like to think of the 818 as a "Plated Racecar."
Here is a link: http://www.wilwood.com/TechTip/TechPedalTip.aspx
Cheers!
Originally Posted by
FFR-ADV
Has anyone here had a lot of luck with the wilwood driver adjustable bias? We ran one on a small formula car years ago and it never worked very well.
