Results 1 to 12 of 12
Thread: $1700 donor in NJ needs head gasket
    NY
    NIce one, wish it was a manual
    Senior Member rjh2pd's Avatar
    Detroit MI
    Subaru quoted me for $1700 or $1800 to do the head gaskets on my legacy so just take that into account. im sure it could be done cheaper and since you are already pulling the engine you might be able to take it to someone and get a major discount if you aren't comfortable doing it yourself.
    Encinitas, CA
    "The hood and roof have dings from parking under a tree and having acorns falling on it."
    Wow, those must be some acorns!
    Mechie3's Avatar
    You can do HG yourself for $300 (full seal kit) if you reuse head bolts. If you buy new head bolts, add another $100 or so.
    Detroit MI
    most of the time you might as well do the timing and other belts while they are off. also the valve cover gaskets, they are know too leak but they are only $20 to $30 for the whole set.
    Beverly Hills, FL
    Based on what I've read, the head gasket is a potential problem area if not done correctly. The gasket sealing area has to be checked to make sure there are no imperfections otherwise you will more than likely experience another leaky head gasket. While I know I can send the heads out (if I do a head gasket myself), not sure how to make sure the cylinders are perfect. This is something I'd want to research carefully before I do the work myself.
    FFR4958. IRS, 408W, Loud and fast!
    Quote Originally Posted by blueoval_bowtie_guy View Post
    For those engine it was just a bad headgasket design. They made a new one after finding out it was no good and no ones had problems with the new headgaskets.
    Freeport, ME
    That's a 200,000 motor, you should plan on an entire rebuild etc... You can't seriously build a beautiful new sports car and put band aids on a 200,000 mile motor... EVERYTHING is worn at 200K :-)
    Milton,DE
    The seller isn't selling for $1700. necessarily. The bidding starts at $1700. Now don't forget shipping, and the engine rebuild. I agree that with 200K on the engine, time for a full rebuild. It would be interesting to see how this auction ends.
    Olli
    Norton, MA USA earth
    Not really a good candidate at that price point if you ask me. All donor parts are pretty well worn. I would find a younger model at even twice the price.
    Just my educated opinion. Theres a reason lots of people no longer go the donor route with the roadster. The donors are just too old. At least the 87-93.
    Mechie3's Avatar
    The rebuild gasket kit includes every gasket for the entire motor (except uppipe to Turbo and down pipe gaskets). The bad hg design was pre 02, but I don't recall the exact date.
