0
0
BS on that running and driving.
Intercooler core is likely full of holes and I can clearly see at least 2 couplers that aren't attached. Even if it was in perfect condition, it would run rough (vacuum leak anyone?). Unplugging the maf, it can run in a default mode, but it'd still run rough and you wouldn't get anywhere.
It probably wouldn't go far. You would surely still want to tow it home anyway. That's irrelevant though because it looks to have a lot of valuable parts on it. Depending on the condition of the engine and transaxle, this may be very donor. It's cheap for a 2007. You would definately need to replace the intercooler and radiator at minimum.
