Originally Posted by
H R Lucky
I searched out the hardware for the hood and mocked it up with duct tape, as far as I can see the pin hole is 3 1/4 in from the edge of the cowl/firewall & I have 4 1/4 in. to the edge of my reservoirs so I should be good, at least I am telling myself that. Thanks for the heads up Dale.
Nevin
It's a real challenge to get them just right when they mount out there because of the frame tube inside limiting how far inboard they can be mounted and trying to keep them as high as possible to help get air out of the system. You have the further challenge of a third reservoir adding to that. The Kugels I used have a different cap that is now at the machine shop getting a bigger chamfer cut on the lids so it won't rub the paint off the bottom of the hood rib. It's that close to the hood and frame both.
This may be one of the changes I suggest to Jim S. for the Gen 2 33 chassis. We have already talked about that area becoming a bent tube VS welded sections we have now.
I'm very much against cutting the big hole in the cowl and mounting them inside because of all the issues with water getting in under the dash. There have been a couple cars that had the fusebox get soaked because of that access plate design.
Dale
Better mouse traps please
wrp liked this post
