With a little searching I found that it will handle 475 ft lbs torque (warrenty 400 ft lbs) and 525 HP (warrenty 450 HP). Is this still the current numbers?
If I am a little over that HP (600HP), I guess I may have to look to another higher HP transmission from Mendeola. Or is/will there be an option to order a higher HP rated Trans from FFR?
