Depends on where your gauge sensor is in the cooling path. Where did you mount your gauge sensor? The Coyote has a seperate sensor used by the controls pack to trigger the fan on and off based on the temperature at that sensor.
Clemson, if I recall correct you put your gauge sensor in the hot side of the heater hose run, correct? I have mine mounted into the block next to the oil filter as per the FFR instructions. I'm not at first start yet so can't comment but seems like it could be a consideration. If you have an OBD tool that can read parameters, you could see what temperature the computer is sensing when the fan comes on.
Kevin
