Location of Brake Line Clip
Has anyone ran into a problem with the suggested location of the brake line clip that mounts to the frame (connects flexible line to caliper)? The way I installed it (per the manual) it seems to be in the way of the engine side panel cover. I've searched every "customer build" for clues to where others have mounted this but couldn't find any that show this particular clip.
If I drill out the rivets and move it to the right (past the control arm mount) I'll be left with two holes in the frame, so I thought I'd ask in case I'm missing something....any ideas? Thanks for your help...
Tech Support Manager, FFR
Hi mike if you look at page 111 in you'r manual it shows the tabs on the tube bye the steering rack and you can also use the same tube just mount it under the tube..
Thanks tony@ffr
Located mine just aft of the control arm mounts for the same reason.
Bill
#420
