0
0
anyone have a set of rear disk brake spindles
my donor came with rear drum brakes and the irs bracket is in the way of the brake line coming out of the wheel cylinder. FFR is aware of this but has not found a solution yet. im thinking of switching over to disks if i can find a set . does anyone know if i have to change the type of master cylinder also when i switch to a rear disk setup vs the stock rear drum system? any advise taken
kerry
