0
0
Safety Wiring Brake Rotor Bolts
I'm thinking ahead for assembling the Wilwood 4pot f/r brake kit for my 818. The kit includes 2-piece rotors, which I would like to safety wire instead of the recommended red loctite.
I haven't found a replacement set of drilled brake rotor bolts that I know 100% will work. I'm posting here because I know a lot of you guys are using the same brake kit. Wondering if any of you have a hardware recommendation or have contacted Wilwood for specifics.
FYI, the brake rotor bolts are 4-28 x.75 - I've only found standard options instead of metric.
