One thing before you paint your shock mount brackets, is to check the fit of the bolts...mine and some others hit the welds on the end you have towards the ball joint hole. Needs some grinding (tho a quick shot with the right size end mill would be easiest) just annoying to have to do after you've painted/powdered it.
You bet! Got caught by that as well.
818 chassis #181 powered by a '93 VW VR6 Turbo GT3582R Go-karted Aug 5, 2016 - Then May 19+21, 2017
Tracked May 27/July 26, 2017 Build time before being driveable on Sep 27, 2019: over 6000h Build Completed Winter 2021
