0
0
818 alignment specs
Hi there! i am wondering what everyone running an 818r is running for front alignment specs. I currently have an 818s and i am trying to figure out how to get more negative camber in the front. I currently have a 1/2 inch spacer in the control arm for the free caster mod, and we also cut out 3/4 on an inch on the front of the upper control arm. Doing this, I have only been able to obtain about a degree maybe a little more of negative camber. I asked this in the regular suspension forum, and didnt have any sucessful responses. I was wondering what all the R guys are doing for this. thanks
-Ryan
ok so far the only way ive been able to achieve any kind of decent negative camber is to bolt my aluminum 06 wrx sedan control arms in the holes for the wagon arms. This in addition to cutting the front adjuster sleeve by 3/4 inch got us a large amount of negative camber. any down sides to changing the mounting point like this?
