0
0
CA Donor car for sale in NYC
Hello all, I'm a longtime fan of the 818, and in fact was planning to build one for some time using my own track built wrx as a donor. However, I recently moved from the San Francisco area to New York City for work. I am not enjoying the WRX as much as I ought to, and don't have the time/money for the 818 build at the moment. The temptation to just hold on until that day comes is huge, but I have finally decided that the best thing I could do with the car is send it into the hands of another 818 builder, hopefully.
The car is a 2005 Wagon, with approximatley 120,000 miles on the odometer. However, the engine was fully rebuilt in 2013. Here's why. I took the car to my first track day in it at Thunderhill, bone stock with 102k miles on the clock. After a couple of laps (with the dreaded sweeping heavy longitudinal loading that I later learned is responsible for a lot of stock EJ20 failures) the engine seized. After a lot of failure analysis and research, I wanted to rebuild the car to handle some light track duty, but it was still my daily driver, so nothing too brutal.
I worked with Boosted Tuning in Chico, CA, to rebuild and tune the car. As the bearings had been spun in the original engine, every piece that ever had oil circulating in it was replaced, and newly honed shortblock and heads, and new crank were used too. The fueling system was slightly overbuilt with an E85 tune in mind, but I never actually ran any corn juice in it. It makes 300hp and 247tq, as reported by the tuner's road dyno session, and the torque curve is nice and flat. It pulls hard all the way to redline, which is set at 7K, in spite of being built for 8k. The engine was broken in carefully, and run at stock boost for 5,000 miles before it was tuned to 20psi. I've used Rotella T6 and Wix filters exclusively, changed at 3500-4000 mile intervals. Once I moved out east, I have barely driven the car during the winter months, so it has seen only as much salt as a California car that occasionally went to the mountains. I really tried to avoid driving it at all, because I just couldn't bear to subject it to that, and the subway system is pretty damn helpful where that's concerned.
Here's what the build looks like, it's been a few years, but I believe I still have the receipts filed (I'll have to dig those up in a couple days, as I'm back in California at the moment for Turkey Day). Overall, I sunk around 14,000 into rebuilding this car, I really wanted the best parts and most reliable build possible. The internal build was directly lifted from the builder's track car, which was tuned to between 365-400hp, and frequently tracked without issue.
Freshly honed stock EJ205 block
Wiseco 92mm forged pistons
OEM rods
ARP rod bolts
New OEM crankshaft
King race bearings
ARP head studs
STI camshafts
Crower valve springs and titanium retainers
Rebuilt OEM heads
Motive composite TGV deletes
STI oil pan and windage tray
Killerb oil pickup
Killerb radiator shroud
Group N motor mounts
Group N transmission mounts
Whiteline steering rack bushings
TiC rear diff bushings and outrigger bushings
Giungyumo fender cowl braces
ACT HDSS clutch, STI sized
ACT lightweight flywheel
Blouch 16G XTR (ceramic bearing)
Process West Topmpount Intercooler
Walbro 255LPH Fuel Pump, E85 ready
Injector Dynamics ID1000 injectors
KSTech Short Ram intake (Causes no MAF issues)
Silicone post MAF hose
Perrin turbo inlet
Grimmspeed 3 port boost control solenoid
XS Catless uppipe with flexible section
MadDad divorced wastegate downpipe
Borla hush cat back exhaust
Parts not installed, but included: Crawford Air Oil Separator (used), thermostatically controlled Setrab oil cooler, STI IC spray kit with boost activated switch
There are three issues with the car currently:
The AC system developed a leak, and is not currently charged
The clutch has started to slip just a little on WOT approaching redline
The powersteering pump failed very recently
I'm asking 13,500 for the car as described, and can deliver anywhere within 1500 miles of NYC.
EDIT: I realize I started writing this post in the donor discussion forum, instead of vehicle classifieds. My bad, mods. Feel free to move it to a better home.
Reason: Misfiled
