0
0
headlight / parking light help
I spent way too long today trying to get this working, help please!
Turn signals run fine no issues
parking lights can't get working, subaru has only 2 wires on schematic, but the new ones (3 small lights) each has 3 wires, but everything I try does not light up. If I take the wires (ground and power) that are supposed to be the lights that turn on with the first turn of the headlight switch (parking, running lights) and connect to the 2 wire turn signal it lights up, but nothing I try gets any of the 3 parking lights to turn on. Anybody have advice, pictures?
Next up trying to wire the headlights to work on a 2003 WRX wagon harness. I am working on adding a relay in to make the
non DRL work. When you turn on headlights (on low) they work, but when hight beam is on to power the shutter, lights turn off, even with help from some on the forum, I can't get the relay to work to make the headlights stay on when high beams are turned on. Hope this makes sense, super frustrated.
