0
0
Ford Bronco donor engine ?
I'm wanting to building a the FFR Hot Rod and planning on attending the build school.
Until then, a donor car came up that I'm interested in and new some insight/help on it. The donor car is a 1994 Ford Bronco Eddie Bauer edition. As I understand things, this has the 351W engine.
I believe it also has a Mass AirFlow (MAF) sensor. Is this correct?
And how difficult would it be to use this engine in the Hot Rod car? From looking at the specs the engine should be straightforward.
But, what about the transmission and drivetrain? The donor car has 4WD on it, does that mean that I can't use the transmission or can I remove the transfer case and use the tranny as is?
Thanks for any help you can provide.
