well, upon further review it seems like there is something wrong with the hyd throw out bearing. Operated the clutch slowly in the quiet this morning,sounded like a squish sound and then 10inch circle of hyd fluid appeared. Dang it. I have to wait a couple days to have access to a lift but it can be one of two things. Either the hyd lines came loose from the throw out bearing,that would be good news, or the bearing itself blew out from being hyper extended( this I suspect). Now trying to explore how difficult it is to move the tko600 back enough to remove the blown bearing. My tunnel has a cut out from the shifter hole rearwards, covered with a tunnel piece attached with pop rivets. If this works its got to be better than pulling the motor.
