This is probably a question more for those that have built roadsters, but certainly anyone with insight is welcome to comment. I appreciate ALL perspectives!
The question is around front tire size. I'm leaning toward running 245/40-17 all around (NOT set in stone), and am wondering how much more difficult that will be to steer than a 225/45-17 (my other - and oft discussed in this forum - front tire size choice).
Background, not directly relevant to the question, but for those that care
My reason is wheel size. I want to stick with close-to-stock rolling circumference to maintain speedo accuracy. I also want to maintian a minimum sidewall height to prevent wheel damage. These 2 combined dictate 17" wheels (I can't get the sidewall height I want while maintaining the stock rolling circumference using an 18" wheel). The problem I've found shopping is that I haven't found even a moderately priced wheel (didn't look at the expensive ones) that is offered in 2 different, appropriate widths in a 17" diameter (i.e. 17x7 or 7.5 for the front, and 17x8.5 or 9 for the rear). I'm really hoping the wheels FFR offers solves this, but I'm almost certain the rears they offer will be 18".
So the simplest solution is to run the same wheel all around (i.e. 17x8.5 or 9). However, this makes a 225 a really poor choice.
So... Opinions? Ideas?
THANKS a bunch in advance folks.
