Wayne your running abs? Can I ask why you are choosing to do so. Looking good man
Would have got more done if people wouldn't call you.. Great progress Wayne!
818R For Sale!
818R Sale Thread
PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
Is the seat mounted yet? The harness openings look much more in line with the bar behind it.
Did you have the same issues with having to remove some minor ancillary items to get it to fit? Any reason you went motor trans first vs Erik's method of suspension then motor?
Zero Decibel Motorsports
Check out my new website!
If im not mistake you should be able to turn abs off via pulling the fuse, or flipping a switch (if installed) without effecting the braking system correct? I would install abs and have a switch in an at least semi hidden place. It's looking good
I'm running ABS to see if it will work and how well it works. Why not, its free with the donor...
The seat is just sitting in the car and I don't know if that is the seat I'm going to use. I put the engine in first because the motor will not be in the way of the suspension install but the suspension will be in the way of the motor install.
Why would I want to turn off the ABS when I could just not install it???
Vary cool build thread there Mr. Very Cool Parts!!
Although I am not building an 818, I really enjoy watching your and Erik's build. You all are really humming along and doing some awesome work! Thanks for keeping us updated. I respect how much effort it must take while also trying to run a business and build a car. It is quite selfless! Thanks!
Please keep us posted; it is really awesome...
I guess you got a point to try to use the abs, I'm not but it might be a good feature. I too will put the engine in first, I am pulling my headers etc, which is on my build thread. I just got home from stripping a donor since 3:30am
Wayne are you running the booster too?
I'll say it again......."I feel sorry for those first guys who start their build"
Wayne !!! where's the sub-woofer going?
Did you drop the engine and transaxle in w/o the header?
you have room to put them on after installation...
Yea FFR had them off when I viewed the s two weeks before open house
I think that I'd like to double up the firewall and insulate between the frame tubes for heat and quiet, thoughts?
Yea that might be a good idea, I like the noise of the engine though, but it might help with slight rattles and creeks, plus some help dramatically with heat
Wayne,
What are these items?
And is the piece round thing that looks like it is copper striped flat up against the block? I think somewhere in this area is where I have a pretty major leak. I'll post some pictures of mine.
818R For Sale!
818R Sale Thread
That is a water to oil heat exchanger, they seem to leak from there but I have now really looked into a solution other than some Three Bond (Yamabond, Hondabond, etc.) on the O-ring.
Add another one to your list of 'watchers'. I think posting moves me from being a 'lurker' to a 'watcher'... Keep up the great work and thank you for keeping us informed!
FFR4958. IRS, 408W, Loud and fast!
That pic reminds me. There's probably quite a few people who would love to know the distance from the front of the crank pulley to the frame rail.
Sexy looking shift gizzy..............
Awww yeah!
Is that an aftermarket boxster shift mechanism or something you whipped up yourself.
Edit: I'm dumb. I was too absorbed by the pics to read anything.
Me likey the shifter!
Thanks- Chad
I really like the shifter too. I've driven a Boxster and was not impressed with the shifter.
So now you have to leave the boot off....can't cover that up, as it's too cool. Maybe design an inverted boot to go underneath.....lol.
I swear I didn't tell anyone... I like that it is lower and looks to have a shorter throw and position capability..
818R For Sale!
818R Sale Thread
It is actually their newest shifter (not the RSX box) that was released last Friday, I'll have a kit for the 818 with cables. It will mate up with the FFR trans brackets and arms. And it will be mounted just like you see, billet out in the open. I just can't see putting a boot over it.
That K-Tuned shifter is striking mechanical art. Thank you for bringing it together for us.
Here is a video I found describing the RSX version (not the same but you get the general idea):
This looks like Wayne's shifter:
http://k-tuned.3dcartstores.com/No-C...ter_p_285.html
Nice Wayne I will have one, lets make a deal
What id the original 818 shifter out of?
Also what are those seats out of?
So this is not a FFR shifter it's K-Tuned?
What are the specs? How short the throw, precision, sound, etc...
I've never seen one looking that good (apart from the Pagani's shifter linkage or is it Spkyer's? Damn I can't recall).
Well I try to cut on my total cost, but WTH, here goes another 430 bucks loll
Tracked May 27/July 26, 2017
Build Completed Winter 2021
I viewed the video. Son of a B this thing has been well designed. The sounds looks amazing and that is on video not installed on any car.
I cannot imagine anyone installing a boot over that, that is like buying a Ferrari and swapping a Toyota Corolla engine in it.
How can you properly adjust that cable stopper? I mean do you have to run the engine and see when the gear engages? Or engine shut off it's sufficient?
