Results 1 to 2 of 2
Thread: Oregon Registration Process
    Aug 2013
    Anyone got info about how to get the legal bs out of the way for a 33 Hot Rod here in Oregon?
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I would start here: http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA and find your State. Read what SEMA has put together and then read through this thread: http://thefactoryfiveforum.com/showt...rmation-Thread
    You can also check with some of the builders local to you and see if they've got any tips etc.
    Good Luck
    Ray
