I'm about to pull the trigger on a 33 Hotrod, and I will use the new 5.0 Coyote motor. I didn't get any help with an automatic transmission recommendation from the FF guys, other than the statement that the stock Mustang transmission would not fit, so I would like some input on the best AOD transmission to use with the 5.0. I have always built cars around Chevy engines, because they were easy, and you could use any engine and transmission combination. I know Fords don't interchange so easily, or at least the older parts did not have good interchange. I was also planning to order the powder coated frame, but it sounds as though I may have to fabricate the transmission mounts, so I'm not sure about whether or not it makes sense to buy the powder coated frame. Thanks for the help.
