Results 1 to 3 of 3
Thread: Cooling & Cooling Fans
    Junior Member GBodyShop's Avatar
    I wondering what is the CFM of the factory supplied cooling fan for the 33?
    And to provide better cooling, would placing a cooling fan as a pusher in front of the radiator and one place in the normal location as a puller help with the cooling?
    Looking at 2400cfm fans for both front and rear location. Will this help in any way or there is no difference?
    Thanks in advance
    wallace18's Avatar
    Trenton, Florida
    Get the fan shroud from replicaparts. My 33 with the kit fan runs 185 all day in 95 florida heat with A/c running with the shroud.
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    Ditto the fan shroud. I'm running a 408 with a lot of cam and compression and she idles at a tick over 180 degrees here in Georgia.
