tmoretta
Thanks for all the info. I do have some questions/concerns: according to the assembly manual - the 818 uses a supplied vent on top of the fuel tank that FFR wants attached to the charcoal can. Can this vent simply be attached to the vacuum port (third down from engine fuel lines) allowing the canister to be eliminated? Isn't the right side engine "green" bracket needed to mount the black plastic coolant fill tank?
Do not hook the tank vent to a vauum source unless it is controlled by the ECU through a carbon canister. You will collapse the tank. It is really up to the builder where to mount the coolant tank. You don't need the lower bracket look at the other build threads.
