2X on the build threads. Lots of good info and ideas. Whether building a 33, 818 or roadster, I read them all I can. What might not be covered on the 33 forum for a particular area of a build may be covered on the roadster side for example. One that comes to mind is how to deal with the body mold seams. I've seen more than one FFR car that when completed, the mold seams showed below the finished paint because they weren't done properly. This topic is covered in detail on the roadster side of the forums. Lots of good engine and suspension advice if you look around the other forums as well. The FFR knowledge and brotherhood is shared across the forums.
If we can help with anything, let us know.
Tim Whittaker
Kootenai Valley Customs
kootenaivalleycustoms.com
