Thread: Has anyone registered a 33 in North Dakota?
    North Dakota
    It seems that it needs fenders but I see a lot of Hot Rods without? Is there any way around this?
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I'd start here: http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA and see what it says about North Dakota requirements. Also, check the ND State web site for it's vehicle code to see what equipment is required.
    Ray
    North Dakota
    Thank you Ray
    Jul 2022
    Curious about the same thing in ND for a 35 truck. Hoping to be able to get around the issue. Plenty of hotrods running around without fenders. If anything I was going to make some cheapo bike style fenders to put on during inspection and remove after inspection. I guess risk getting a ticket. Where u located Mike?
    Jun 2020
    SoDak
    I would imaging ND is going to be fairly simple like SD was for me (not a lot of rules) but I'm not sure.
    Jim
    Quote Originally Posted by Ray View Post
    Ray
    I couldn't get to this page, but here's the map I used when I was looking into it. You can click on any state and see the laws:
    https://www.semasan.com/resources/ev...-all-50-states
