There is now way I am going to get the lower spacers in on the front shock mounts. They are simply too big. I was thinking I would use a stack of washers for the rear spacer on the lower mounts. Any suggestions out there?
On my 818 I had similar problems... I use a belt wheel on my bench grinder to trim them down
Dan
I have always just used a belt sander to trim as needed.
Doug
Thanks for the suggestion. Santa came (via Harbor Freight tools) and I have a angle grinder. Voi-la the now fit just fine. Thanks for all of your help!!
