Thread: Is a 2008 WRX Turbo short block interchangable with a 2007 WRX turbo short block ?
    Kirkland, WA
    If I have a 2008 WRX Turbo short block can I interchange that with the rest of my 2007 WRX Turbo engine parts
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    I believe it'll bolt right up. No issues. Your 2007 heads and ecu shouldn't have any problems running on a 2008 short block.
    Kirkland, WA
    Quote Originally Posted by Rasmus View Post
    So I gather the cases are identical (the '07 is a EJ255 and the '08 is a EJ257), the pistons are different and will add to the C/R and thus not sure how they would match to the EJ55 heads
    Tony Nadalin
    Aug 2013
    WRX blocks are 255
    Check the casting number, but otherwise yes.
    Mechie3's Avatar
    Indianapolis
    Sort of related, but I'm running 09 WRX heads on my 06 shortblock (purchased new in 2010). The heads are D25 heads, so I would assume the blocks are EJ255 as EJ257 blocks on B25 heads would make for high compression.
    Zero Decibel Motorsports
    Check out my new website!
    Aug 2013
    Short blocks are the same.
    WRX heads are 50cc, STI is 57cc
    Senior Member BrandonDrums's Avatar
    Triangle area, NC
    Quote Originally Posted by D K View Post
    There is a slight difference in Pistons between the EJ255 and EJ257 but nothing worth worrying about. This thread (too bad the picture links have expired) explains the differences which really comes down to a very slight difference in the dish shape.
    http://forums.nasioc.com/forums/show....php?t=1667168
    Heads vary more from year to year, there are many different versions of EJ257 and EJ255 heads. The long short of it though is that if you have a set of matched heads from either a 255 or 257 and want to use it with a 255 shortblock or 257 shortblock you're fine. They will bolt right up and not cause any major issues as long as you're getting a custom tune.
    No matter what combination you run, it will change areas in the rev band where knock conditions are more sensitive due to different shapes in the combustion chambers and different compression ratios so you'll need a custom tune rather than an off the shelf map.
