Thread: C-5 Vs C-6
    Dec 2013
    Oceanside CA
    C-5 Vs C-6
    I apologize, I am sure this question has been asked and answered elsewhere in the forums, but I am not having any luck finding it. I am doing research on building a GTM and have some questions regarding chassis/suspension and various other components. Looking through the required parts list and with the understanding it is based off a C-5 platform, will components from a C-6 work the same? I.E.; control arms, brakes, parking brake, steering column, cooling system, ignition switch, throttle, wiring, fuel tanks, wiper motor, window regulators and all other sub-components and systems necessary to complete the build.
    I plan to run an LS7 and with that, I would like to buy a salvaged C-6 for a donor and have everything I need for the build in one shot less the transaxle, instead of buying all the components separately.
    So all that to ask, do I need to look into a C-5 donor and find my LS7 and computer/harness elsewhere or am I good to roll with a C-6?
    Thank you very much for your time, It is appreciated.
    Nate
    Fresno, CA
    Welcome to the forum Nate. I am sure some of the GTM builders will be able to answer your questions shortly.
    Doug
    Dec 2013
    Oceanside CA
    Thank you for the warm welcome Doug
    Hi Nate,
    Your question has a very involved answer. You do need to post in the GTM forum to get the answer. The short answer is yes, with a few no's.
    Start by looking at this awsome build, http://gtm410.com/
    Good luck,
    Gene
    Dec 2013
    Oceanside CA
    Much appreciated Gene
    Tech Manager, FFR
    Hi Nate,
    Welcome! Gene makes a good point. My advice is this: We designed the car around the C5 and didn't take a C6 apart to determine what would or wouldn't work, but I know that the spindles/brakes will work, and so will 2008 fuel tanks (maybe the whole range?). Either way, maybe some others from the GTM forum will have tried to use a C6 and can provide some more info.
    Good luck!
    Jason @ FFR
    Dec 2013
    Oceanside CA
    Thanks for the input Jason, I'll resubmit my question in the GTM fourm.
