Thanks Thanks:  3
Likes Likes:  7
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 267
Thread: H6-EZ30 engine in the 818----IT FITS
  1. #201
    Hi guys. Just found my way here while googling for EZ30D conversions and turbo set ups. I'm currently running one of these motors retrofitted into an earlier Gen2 Legacy (called a Liberty here in Australia), with the factory H6 ecu and a dual range manual conversion. The most common trick to stop ECU codes popping up with a manual setup is to ground the neutral switch at the ECU, which is what has been done to my car. It's not ideal though as its struggles to idle smoothly and occasionally stalls when coming to a stop and pushing the clutch in, which is scary when the break vacuum and power steer suddenly disappears.
    I recently found this thread on RS25.com where someone has wired up a transistor to trick the ECU into manual/auto when the clutch is pushed in to solve the problem I have with mine.
    http://www.rs25.com/forums/f145/t155...z30d-swap.html
    I'm very interested to see how you go with turboing this motor. I off-road my vehicle so would be looking at a high comp - low psi setup like Wayne is talking about, and was just looking at those same Garrett turbos.
    For those that haven't driven a H6 with a manual they have the same torque and hp as a factory turbo and they go like it too, with no lag! In factory form the auto is an ugly power sucking parasite and doesn't do the motor justice.
    A short video of how my H6 sounds tearing up a sand dune Down Under
  2. #202
    Senior Member StatGSR's Avatar
    Duluth, MN
    Nice to see a guy that has actually completed an EZ+Manual swap on this site! i suspect when others see your post you might be getting inundated with with wiring questions! welcome aboard!
    05 Outback XT - DD
    94 Integra GSR - Track Car
    97 Legacy Brighton - EG33 Swap Project
    03 Silverado 2500HD Duramax - Tow Rig
    97 Integra GS - Future Track Car
  3. #203
    Senior Member Silvertop's Avatar
    Forest Lake MN
    I love the sound! As predicted, its pretty much the same sound you get from a 6-cylinder Porsche. And that is very sweet indeed!!
  4. #204
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Vroom Vroom
  5. #205
    Fort Lauderdale Fl.
    Sounds good!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
  6. #206
    San Diego Ca 92106
    Hey Wayne do you have a list of parts needed to make this conversion beside those supplied buy an impreza donor?
  7. #207
    Edmonton, Alberta
    To my knowledge there's only a few things to fabricate. 2-1 coolant line, exhaust and intake. As for the wiring, either tackle the OEM, or buy a harness and standalone from Wayne.
  8. #208
    Jan 2013
    You may want to check if there is a change in weight distribution, front and rear.
  9. #209
    Administrator
    Enterprise Alabama
    If you go NA you will have to make an inlet tube to the airbox/MAF sensor.
    Quote Originally Posted by Mifune View Post
    Uh it's only 17 lbs, mounted in exactly the same location so the weight bias may change .9% My car with the turbo H6 is 59.7% rear and 50/50 in side and cross weights
  10. #210
    Senior Member Flamshackle's Avatar
    Aotearoa (New Zealand)
    Thats awesome!
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  11. #211
    Edmonton, Alberta
    Does the EZ use the same engine mounts as the EJ? I doubt there's any stiffer aftermarket mounts for the EZ.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  12. #212
    Administrator
    Enterprise Alabama
    The frame mounts are the same, the ones on the engine are completely different.
  13. #213
    Edmonton, Alberta
    Thanks Wayne. After asking the question I did come across it mentioned a few times that STI (not sure how STI/non-STI could matter) mounts have been used on EZ's. Despite the EZ being a 3 bolt design and the EJ being a 2 bolt, it only requires slight modification...supposedly anyway, I've yet to find any proof. Might be easier to use the used mounts and install a dampner versus modifying aftermarket EJ mounts.
    818 SRX - #91
    Arrived 01/02/2014
  14. #214
    San Diego Ca 92106
    I'm exploring options. If I go with an EZ30, and kept it NA, I don't think I'd be satisfied with 250 flywheel HP. So what can one reasonably expect with the traditional power adders.
    http://www.raptorsc.com.au/kits.php?id=70
  15. #215
    Edmonton, Alberta
    Hard to say where it'll dyno with good headers and less drivetrain loss. Personally, I think 250rwhp NA trumps 300rwhp turbo any day of the week. They can really benifit from some valve train upgrades as well. Not sure if any of the headers pictured above would fit the 818 well.
    818 SRX - #91
    Arrived 01/02/2014
  16. #216
    Administrator
    Enterprise Alabama
    The EZ30 should put out about 350 at 6 psi of boost based on pressure ratios. (20.7/14.7*250)
  17. #217
    QC, Canada
    Wayne, on stock static CR, right?
    And stock CR cuz aftermarket parts to lower the compression on this engine are hard to find?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  18. #218
    Member tango68ss's Avatar
    Mar 2014
    Vroom Vroom
    Any new updates Wayne? Hows the fit-form-function, etc?? Headers? Just really interested in this set-up.
    TC
  19. #219
    San Diego Ca 92106
    Wayne, do you see any problems using a two to one coolant adapter with a fill cap, or would it be better without?
  20. #220
    Administrator
    Enterprise Alabama
    He put it in this one because the tube was higher than the top of the radiator. In the 818 you would just need to run a line to the degas tank from the 2 into 1.
  21. #221
    Sgt.Gator's Avatar
    Bend, Oregon
    Wayne I live in Outback/Legacy Wagon/Tribeca country, there are tons of wrecked EZ36s here. For example a 2011 30K mile EZ 36 complete engine assembly is available from a local wrecker for $2500. Will your harness + ECU work on a EZ36? Any issues you can think of about using an EZ36?
    Owner: Colonel Red Racing
    818R ICSCC SPM
  22. #222
    Jan 2012
    I know an iWire harness would work very soon.
  23. #223
    Hey guys. Where are we at on the EZ30 setups? I have until January to make up my mind
  24. #224
    East Hartford, Ct.
  25. #225
    Senior Member Turboguy's Avatar
    Canada
    Quote Originally Posted by JB91710 View Post
    What.........the..........
  26. #226
    Jul 2012
    Encinitas, CA
    That's so crazy... I like it.
  27. #227
    East Hartford, Ct.
    Quote Originally Posted by Xusia View Post
    Engine management??
    You got that right!!!
  28. #228
    East Hartford, Ct.
    Quote Originally Posted by 07FIREBLADE View Post
    Don't hold your breath though. I've been talking to them for over a year now and as recent as two days ago and they can not run an EZ30 at this time.
  29. #229
    Do I understand correctly that the only reasons not to use an OEM harness on a NA EZ30 would be the weight and some trickery with the manual transmission? What happens with the transmission swap?
  30. #230
    East Hartford, Ct.
    Quote Originally Posted by turbomacncheese View Post
    It's a moot point anyway. I just found out the electronics to run my engines with Motec is going to cost a whole lot of money.
  31. #231
    East Hartford, Ct.
    If one pair is good, why not two?
  32. #232
    San Diego Ca 92106
    Ha, the ez36 is going to need something a little different . I'm getting some inspiration from what the GTM guys do, my headers will be similar to what they do with the angle that the headers will have to make between the engine and frame. I have yet to decide whether to use a H pipe or an X pipe. I think that space will limit me to a H pipe even though the X pipe would look cooler.
    Don't give up on your project to soon, theirs has to be a more cost effective solution out there.
  33. #233
    Senior Member DSR-3's Avatar
    San Jose, CA
    I figured out what those corrugated tubes in the kit are for! They will probably outlast my oak header flanges.header-test1.jpg
  34. #234
    Nepa
    Quote Originally Posted by DSR-3 View Post
    nice flange! do you know if the 30 and 36 would take the same flange or complete header? or are they different
  35. #235
    San Diego Ca 92106
    Clever and effective. Will you be adding a H pipe?
  36. #236
    San Jose, CA
    Quote Originally Posted by Samiam1017 View Post
    It looks like they use the same gasket (44011AG040) so maybe the flange is the same. As for the header, it depends on the engine location. Those pushing it back to clear the cam phasor hump(s) probably can't fit the header I'll build.
    Also worth noting- re. "equal length" headers, 2 of the exhaust port in the head are "un-equal-length. Cylinders #1 and #6 are ~1" longer...
    re. H or X pipe- I won't start with one, but there will be a place for one between the collector transition and muffler. I've only done a bit of research on it, but on a 6 it sounds like there's not a great performance increase from an H or X, but the effect on the sound may be a consideration.
  37. #237
    Oh damn it... are you sure on cylinder numbers? I thought the heads were not interchangeable side to side.
  38. #238
    San Jose, CA
    Quote Originally Posted by craigfree View Post
    Location I'm sure of- but the numbering is from a sketch I made many months ago; #1 (front right) and #6 (rear left) are the long-ports. I don't see how the heads could be interchangeable.
  39. #239
    Then it's cylinder 2 and 5, but I still didn't model it in.
  40. #240
    Administrator
    Enterprise Alabama
    DSR has the numbering right, odd cyl are right, even are left
