Looking good. I got mine from DatonaBill and used flat head machine screws. First tape install to make sure they fit and where to position them
Painted them and reinstalled. The paint match isn't perfect and I will probably do a permanent install w/ glass and have the rear re-painted.
I got 35 mm spacers to move the 315s outward. Since I had not moved the 3/4x3/4 tube that goes to the door latch when I did the 315 mod, I was always rubbing it. The spacer fixed it but I keep thinking about 335s.
