Russ Thompson turn signal wiring
I started wiring the Russ Thompson turn signal last weekend, and everything went pretty smooth although I do have a few questions on one thing.
I used the schematic shown below, and on the on the 4 count terminal connector next to the "blue" connector from the RF harness it shows a black wire that says: "To headlight switch feed 2"
Questions:
1. Is this supposed to be an existing wire or a new wire I need to make?
2. What gauge wire should I used if it is a new wire?
3. I used 18gauge wire for all the other connections and loops is that sufficient?
Thanks for the help,
90 views but no answers?
Somebody out there has to have done this before!
John I don't have the RT turn signal switch (wish I did) but I do have the RF harness and the wiring diagram shows that the head light switch has two RED wires labeled HDLT SW 1 FEED and HDLT SW 2 FEED. Take a look at the wires and match the gauge. I would guess 14 gauge. I recommend you get on the RF website and ask a tech question about the gauge wire. Wish I could be more help.
