Thread: How to remove the brake booster ??
    Virginia
    I have been making good progress the last two days. But I have run across a problem removing the brake booster. It seems to be blocked by part of the
    Cassie. IT is loose but will not come out completely. Any suggestions welcome . Thank you GRAYGHOST
    Quote Originally Posted by grayghost View Post
    there is a pin that attaches it to the brake pedal. Remove and SAVE the pin.
    Virginia
    Bob, thanks. I removed that pin with the spring clip. Now what. RLM
    Post a picture where it is hitting.
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Here's the great part about that, you can leave the booster in the car. Just remove the master, clevis and lock nut as you do not use the booser in the 818.
    Virginia
    When I went down to the Car this morning I took a hard look at the problem, and found the shock/strut tower is in the way. My friend Victor was with me and he was in the car
    and I was outside pulling the booster out. Between the two of us it came out !! Thanks for your helpful answers.
    Now just the rear suspension and gas tank, and its off to the salvage yard. RLM
