Results 1 to 12 of 12
Thread: How to Remove adhesive from powdercoat?
    Senior Member esff32's Avatar
    La Verne, Ca
    Does anyone have a product or trick to remove adhesive from powdercoat without damaging it? I used a bit of goof off in an inconspicuous area inside on the backside of the firewall and it turned the powdercoat grayish. The finish is a low gloss or satin and most removers are pretty harsh. Any thoughts and/or ideas fellas? Thanks for the help.
    Evan
    Senior Member Arm7419's Avatar
    Sedona Az
    Try WD -40
    Chuck
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    La Verne, Ca
    Thanks Chuck, I will give it a try.
    Aircraft Spruce sell a Paint Cleaning Solvent. Best stuff I have ever used. Use it on powder coat and paint on my Cobra all the time. I have a gallon in my shop because it takes off most adhesive better than anything I have ever seen. Works on other stuff too.
    hershey, pa
    Lighter fluid works well on most adhesives. Doesn't harm plastics or paint.
    los lunas NM
    furniture spray wax, works well on taking off labels also
    Mar 2013
    Fort Collins, Colorado
    3M makes an adhesive remover part number 08984. It is available at any automotive paint supply store. Will not harm paint, powder coating or anodizing. It's also handy for many other uses around the house.
    "The I.E." SoCal
    Quote Originally Posted by Arm7419 View Post
    Try WD -40
    X2 let it soak a bit and adhesive will dissolve. Then just wipe off.
    __________________________
    south-central CT
    mayonnaise. Works on many adhesives. Let it sit for a while. Before that try super strong duct tape. It might pull it off.
    http://googone.com/GG-Browse-Product...Spray-Gel-12oz
    Best stuff I've found for removing nearly any kind of adhesive, etc. and a general useful cleaner to have in the shop. I've yet to find a surface it harmed. Another forum member mentioned it some time back and that's when I tried it. It's at Walmart, Home Depot, etc.
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    Again, WD-40 or even better still eucalyptus oil.
    La Verne, Ca
    Wow, you guys are awesome! Thank you very much for the help.
