Thanks Thanks:  2
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 366
Thread: THE Wheel & Tire Thread
  1. #161
    Quote Originally Posted by wleehendrick View Post
    R888's are what I'm thinking of, that size in front. On a 17" front rim, R888's would require dropping to 205's, or possibly rubbing with a 215-225/45-17. I see you have th 02-05 brakes. My donut is 16" and Tirerack shows 16" ('-1') wheel fitment for the 06 WRX, so I'm hoping there's no clearance issues with the 4-pots, just want to hear from someone that's tried it.
    The brakes and wheels in that picture are off an 06 NA wagon 277mm front rotors.
    My second donor is an 04 FXT with larger front rotors 294mm but still only 16" wheels.
    06 wrx has 294 mm rotors
    06 sti has 326mm rotors.
    I think you can conclude the 294mm rotors will fit in 16" wheels because of my FXT.
    Jul 2012
    Encinitas, CA
    Thanks for the info... 16" should fit in front, but now the issue is wheel choice. I can't find anything that's available in a 16x7.5(+/-0.5) and 17x9.0(+/-0.5) with a 5x100 pattern. I may just go with 17x7 & 18x8.75 XXR's, with 215s in front, like GRM did.
  3. #163
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    ...I'm thinking a 255/40-17 in the rear which would provide a nice staggered set-up. The 30mm width difference seems to be recommended for balance, and aesthetically, I think the same sidewall height with a 1" larger rear wheel will look best.
    Thoughts?
    I don't know for sure, but I wonder if the additional sidewall height (vs. a 215/40-17) would negate the additional 10mm of width.
    ...I may just go with 17x7 & 18x8.75 XXR's, with 215s in front, like GRM did.
    I have the XXR 530's in those sizes, and I put Federal 595 RS-R tires on them: 215/40-17 in front, and 255/35-18 in back. They fit very well. And since the sidewall height is nearly identical (89mm & 91mm, respectively), It's hard to even notice the size difference. It's a really good looking and well fitting combination.
  4. #164
    Jul 2012
    Encinitas, CA
    Quote Originally Posted by Xusia View Post
    Any of the 225/45-16 tires I'd want (R888 for example) have stiff enough sidewalls, I don't think it's an issue.
    I've been thinking about that exact combo (chromium black rims) for a while, so if I end up with it, I hope you don't think I'm copying you!
    Thanks for the info,
    Lee
  5. #165
    Eugene, OR, USA
    Hahaha! Not at all. I hope my experience is helpful.
  6. #166
    Suisun City, CA
    Here's my setup:
    17x8 +45 (using 10mm spacers, making the effective offset +35)
    235/40/17 Federal 595 RS-R
    18x9.5 +45 (using 13 mm spacers, making the effective offset +32)
    265/35/18 Federal 595 RS-R
    VCP Trailing Arms
    4.5" ride height
    "Free caster mod" on the front. This is basically adding 10mm aluminum spacers between the front lower control arm aft mount and the arm itself.
    I only have minimal tire rub from the front end, on the aft section of the inboard aluminum.
    Not my picture, but this clarifies the "free caster mod":
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  7. #167
    Exeter R.I
    You have a honda fit also, lol
    Jdm engine, honda fit, 818 small world, looking good, did you get a price on a new front bumper, I am wondering what they cost, cause at some point I am going to trash mine as well. I get my tags weds, I would have had them Friday, but I had to get the title person to issue it and they were not back till weds.
  8. #168
    Suisun City, CA
    Not yet, I haven't even sent an email yet. I'll probably send one tomorrow. It's toward the bottom of the list right now. I'm trying to tidy up and finish a lot of other things.
    Finished: NEVER!
  9. #169
    Jan 2012
    Do you need to do this caster mod to essential run a +35? Or it's ideal because of adjustability?
  10. #170
    Suisun City, CA
    Quote Originally Posted by 07FIREBLADE View Post
    It allows you to run a slightly wider tire up front.
    Finished: NEVER!
  11. #171
    Clovis, Ca
    Quote Originally Posted by JeromeS13 View Post
    Jerome- You are giving me hope on running a 235/40 R17 Toyo RR race tire. Do you think by adding more camber (2.5+), and using the R height that will help the inside rubbing or hurt?
    Thanks- Chad
  12. #172
    Suisun City, CA
    Oops. I forgot to mention, I'm running 2.5' negative camber up front and 2.0' in the rear.
    Finished: NEVER!
  13. #173
    Clovis, Ca
    I ordered up the "Pirate" Tires- Toyo RR's- 235/40 R17 and 255/40 R17, wish me luck.
    Thanks- Chad
  14. #174
    Kirkland, WA
    Bad boy, I can see re treads coming your way from old RA-1s
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  15. #175
    Senior Member Kalstar's Avatar
    Cape Cod
    Since I have 100% decided my 818 will be black. I have been getting ready to order wheels. All three of these wheels are 3 piece and are from a company name Niche. This go around there will be no budget, but I do not want to make a costly mistake.
    Opinions on which wheel will look best??
  16. #176
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    I like 1&3 best. Can you get different colors rims on #3?
  17. #177
    Clovis, Ca
    I have a roller!
    Front 235/40 R17 Toyo RR (17x8 +38 with 3mm spacer for now)
    Rear 255/40 R17 Toyo RR (17x9 +40 with 5mm spacer- Clears regular WRX trailing arm fine- but car still need alignment)
    Thanks- Chad
  18. #178
    Cape Cod
    Yes, I can get any color I want.
  19. #179
    Exeter R.I
    Quote Originally Posted by Kalstar View Post
    You bold man, that looks killer man
  20. #180
    Eugene, OR, USA
    I'm with Wayne. I like #1 & #3. I have a slight preference for #3.
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
  21. #181
    Administrator
    Enterprise Alabama
    then #3 for sure!
  22. #182
    Senior Member TahoeTim's Avatar
    Mar 2014
    Lake Tahoe
    be different - go with #3, add small bronze accents/stripes and do a BROWN interior. I am waiting for someone to do a brown interior.
  23. #183
    south-central CT
    Although I'm looking at racing and will do something much like C.Plavan's wheels (which I like a lot), I like #2, the Niche Geneva H520. What about red or lime green rims? I wonder how much they weigh? The car begs for light wheels and tires.
    Now that I know 235's work in the front, one of the first things I will do is see how my 18x10.5" Enkei RPF-01's (38ET) with BFG 275/35's (off the STi) will fit the rear.
  24. #184
    Anyone see any issues running a front setup of 17 x 8 + 35 offset w/ 225/45 & a rear of 18 x 9.5 +40 offset w/ 255/35's?
  25. #185
    Administrator
    Enterprise Alabama
    Quote Originally Posted by GUNS View Post
    Yes, fronts are going to be too large in diameter
  26. #186
    So I would probably need to go with a 215/45 up front with that offset?
  27. #187
    Jul 2012
    Encinitas, CA
    It's the diameter that's the issue; others have posted rubbing issues with stock Subie diameter (25") tires. 215 vs 225 tread width does't really address the issue, you need a thinner sidewall. I'll be going with 215/40-17 (around 24" OD). Same size as the GRM car:
    http://grassrootsmotorsports.com/pro...ot-wheels-818/
  28. #188
    Richmond, VA
    I have been doing a lot of web searches trying to skin this cat. I set a challenge for myself, and think I finally solved it. Here's what I wanted:
    1) Widest tires possible without rubbing.
    2) Fill the wheel well. Don't stick out.
    3) Be able to use Federal 595 tires.
    4) Bolt on. No spacers or adapters. I'm sorry, I think these burn money that can be used elsewhere more effectively.
    Here's the only set I've found so far. PLEASE, correct me if I'm wrong!
    Drag DR-31 wheels Front: 17x8 35mm offset 215/40-17 tires. Rear 18x9 38mm offset 255/35-18 or 245/35-18 tires. I prefer the 255, but the 245s would give me an extra .2" of clearance on the inside if I need it.
    The only thing I don't like about these wheels is that they are a little heavy. 21# & 24# respectively. About $600 delivered but lots of money saved on spacers.
    Thoughts?
  29. #189
    Clovis, Ca
    Quote Originally Posted by thall818 View Post
    Thoughts?
    I do not know where you are buying your spacers, but they are cheap.... And cheap insurance to getting a wheel to fit right, or fit at all for that matter.
    Thanks- Chad
  30. #190
    south-central CT
    Personal preference perhaps, but I do everything I can do to avoid using spacers. If you race you probably want ARP (or equivalent) longer studs with spacers. That adds weight and cost. Spacers add weight and cost. Both are unsprung weight.
    Spacers add one more thing to possibly add eccentricity and mess with balance. I've had racers tell me to avoid using them. I know they are somewhat common, but on race cars? Also, cheap = more potential for poor quality.
    Has everyone seen the lightweight wheel list? There may be others or this may be a version of a better one. I have an extensive spreadsheet at home, but it is not available to me right now.
  31. #191
    Clovis, Ca
    All I'm saying a 5mm or 3mm spacer is nothing on a 1800 pound car. I challenge anyone to see if they notice the additional few ounces of unsprung weight. Also note the hub/bearing capacity is more than twice that of the 818 weight. The minimal load of a 5mm spacer in negligible.
    I would rather error on the side of needing a spacer and being able to use the wheel, than not to need a spacer and the wheel does not fit and you cant use it at all.
    Also keep in mind that tire measurements are not exact either... So there is not a perfect world until you test fit the tire and wheel combo.
    Spacers=cheap insurance.
    Thanks- Chad
  32. #192
    Richmond, VA
    On the high end, ISC sells their wheel spacers for $150/pr. On the low end, I can get thin ones for $5 ea. After buying longer ARP studs, it can be done for as little as $75.00. I'm not trying to knock anyone for a $75 purchase. All I'm saying is that if I can solve the puzzle and save $75, it's worth it to me. Not to mention that I love a challenge.
    I think just finding a wheel that is offered in both 17x8 and 18x9 is hard enough.
    Don't forget, I'm also the cheap guy that is starting off with the low cost Federal tires and making sure I buy a rims that can use them.
  33. #193
    I can't see spacers adding weight, since low offset wheel simply have less metal removed. Some wheels will have deeper dishes if they are designed around that offset, but not usually.
    I look at spacer cost the other way around. Spacers free me up to have five times as many wheels to choose from. The odds of finding a bargain that makes up for the $75 is pretty high. Also, with the 818 being new, it's safer to get too much offset and space to fit since you can buy the wheels, measure, then order the right spacers. If you have a no-spacer plan, the wheels better fit. The worst case scenario is that your low-offset wheels need to move in.
  34. #194
    Clovis, Ca
    Quote Originally Posted by Jaime View Post
    That is another great way to look at it.
    Thanks- Chad
  35. #195
    Feb 2014
    The issue with spacers and racing is balance. Particularly on a hub centric setup.
    If the spacers aren't machined perfect, your wheels will be out of balance.
    How noticeable that will be, depends on how far from perfect the spacers are.
    Unbalanced wheels at high RPM induce handling instability and put undue wear on bearings.
    Again depending on how well or poorly they are machined. And as thin as the spacers being discussed are, how evenly they are torqued (unless they are made out of a harder metal than the wheel).
    But in all likelihood, unless they are way off, decent spacers will likely be pretty negligible for this application.
  36. #196
    Hi guys I noticed Advi.1 has quite a few wheels in the sizes we need and 35 mm offset.
    Has anybody heard anything good or bad about these?
    http://www.wheelplususa.com/wheels/Adv1/
  37. #197
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Forged wheels. Not sure about the reputation but for $1600 a corner, you could go with a set of Ray's which have a legendary reputation. http://www.rayswheels.co.jp/
  38. #198
    south-central CT
    What he^ said! That's a lot of dough. They appear to be two-piece. They would need to be light AND strong for that money.
  39. #199
    Tucson, AZ
    Alright guys. I'm looking at getting the following wheels and wanted opinions if there would be any fitment issues:
    Front - XXR 522 17x8.0 Flat Black 5-100/5-114.3 [+48mm] - Part # 52278102 ( 24.5 lb )
    Rear - XXR 522 18x8.5 Flat Black 5-100/5-114.3 [+48mm] - Part # 52288102 ( 21.6 lb )
    I'd wrap them with Federal 595 RS-R 215/40/17 front and 255/35/18 rear.
    My question is.. is the +48mm offset alright or would I need to get 3mm - 8mm spacers for some reason? I can get all 4 shipped for $502 so it would be great if these will work out.
  40. #200
    Hindsight's Avatar
    Atlanta
    You will prob need spacers but they are cheap. You want a 35 to 40 offset roughly.
