Results 1 to 40 of 79
Thread: RoRi's Custom Parts Feeler Thread
    rori's Avatar
    Tulsa, OK
    Some people expressed interest in some of the parts I made for my 818 build. I'd like to see how many would be interested in these parts before I commit to a vendor subscription.
    1. Steering Column Spacer: $50
    http://thefactoryfiveforum.com/showt...l=1#post142721
    2. Shift Rod Arm (requires K-tuned shifter): $70
    http://thefactoryfiveforum.com/showt...l=1#post142723
    3. Push/Pull Cable Bracket(optional) (requires Shift Rod Arm/K-tuned shifter): $50
    http://thefactoryfiveforum.com/showt...l=1#post144793
    4. Radiator Spacers: ETA 5/29/14 $60/pair
    http://thefactoryfiveforum.com/showt...l=1#post148797
    Updates:
    3/13/14: Thanks for the great response guys. I'm going to order an initial run of 15pcs of the spacer and 10 of shift arm; ETA: 4/14/14. Hopefully I'll have the push/pull bracket finalized soon for those who were interested in it.
    3/22/14: Cable Bracket finalized. See post #30
    4/2/14: Cable Brackets ordered. ETA: 4/14/14
    4/18/14: Steering column spacers and shift arms are in stock. Cable brackets are scheduled for delivery 4/22/14. PM's will be send out that day to people on the list.
    4/28/14: First round is Sold Out. Radiator Spacers are expected 5/29/14. Shift Arm/Bracket/Steering Spacers are expected 6/4/14.
    Interested parties:
    1. AZPete - PMed - Paid
    2. Xusia - PMed - Paid
    3. svanlare - PMed - Paid
    4. Triathletedave - PMed - Paid
    5. JeromeS13 - PMed - Paid
    6. bompus - PMed - Paid
    7. metros - PMed - Paid
    8. metalmaker12 - PMed - holding
    9. Joseph - PMed - Paid
    10. longislandwrx - PMed - Paid
    11. FFRSpec72 - PMed - Paid
    12. DruOdil - PMed - Paid
    13. cmcintyre - PMed - Paid
    14. grayghost - PMed - Paid
    15. Quiny - PMed - Paid
    Group 2:
    1. coloskydiver
    Frank818 - PMed
    07FIREBLADE -PMed
    Outwest - PMed
    Shift Arm:
    2. wleehendrick - PMed - Paid
    3. JeromeS13 - PMed - Paid
    4. bompus - PMed - Paid
    5. metros - PMed - Paid
    6. C.Plavan - PMed - Paid
    7. cmcintyre - Paid
    8. DruOdil - PMed - Paid
    9. K3LAG - PMed - Paid
    10. grayghost - PMed - Paid
    Group 2:
    drdracing - PMed
    Outwest - PMed
    Push/Pull Bracket:
    7. cmcintyre - Paid
    Group 2:
    drdracing - PMed
    Outwest - PMed
    Radiator Spacers:
    1. FFRSpec72
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    Encinitas, CA
    I'd be in for the shift rod arm and cable bracket (I have the VCP/K-tuned shifter).
    Can you remind what the steering column spacer is used to fix?
    Leesburg, VA
    Would the shift rod arm be compatible with the FFR shift cables if the rod arm is pointed downward instead of upward for the k-tuned shifter?
    Senior Member AZPete's Avatar
    I'll buy the Steering Column Spacer, for sure.
    Maybe buy the shifter parts - if I decide to get the K-Tuned shifter. Trying FFR shifter first.
    Chicago, IL
    Likely in for the shift rod arm and bracket.
    I'd like to see a few specs or bits of info on it first - like how much room does it save you over stock, do you have to modify the trans rod, can it be mounted facing down?
    Let us know.
    Best,
    -j
    Executive Director
    The Community Garage
    rori's Avatar
    Tulsa, OK
    No, the ball joint for the push/pull cable would be on the wrong side. The FFR instructions also have you bend their bracket back towards the front of the car because of the angle that the input shaft comes out of the transmission; that wouldn't be possible with this one and it would be pointing out towards the rear of the car.
    rori's Avatar
    Tulsa, OK
    There are links above each picture to the appropriate post on my build thread for a little more info and pics installed.
    Let us know.
    Best,
    -j
    Approximately 40mm, no, and no.
    Leesburg, VA
    Quote Originally Posted by rori View Post
    OK, could you simply make a second version that had that threaded hole on the other side so that it would work with the FFR cable? I think I can take care of the bend with a vise and a hammer.
    Mechie3's Avatar
    Be careful, 6061 aluminum doesn't like to bend. It likes to crack and break. I'm not sure how important it is to straighten it out anyways. The angle or rotation isn't very much so the change in Y (front to back of car) isn't much.
    Zero Decibel Motorsports
    rori's Avatar
    Tulsa, OK
    This is why I would not try to bend it, I would expect it to break also. I don't know if the clearance is important or not as I am not using the FFR supplied shifter. It should be easy enough to create the part in a mirror image, I just can't test it out to see if there are any unforeseen issues.
    Also this would require a new bracket for the push/pull cable that would need to be compatible with the existing FFR bracket or replace it altogether.
    Totally down for a shift rod arm, lovely piece of work.
    San Diego & Riverside CA
    I would b in for one of each, Dru
    Yeah I know but I didn't see the explanation on the steering spacer. Or it was more than a few posts away from the picture and I missed it.
    Frank, I believe that spacer allows you to press the collapsible column down 2.5" or so and still mount it using the factory mounting holes.
    without a bracket like this you only can shorten the column about an inch and redrill holes, and use the FFR provided spacers. after that you run out of bracket.
    Nov 2012
    Medina, OH
    It seems to me that mounting the shift arm closer as in the above shift arm would be similar to using FFR's setup with the bend. I guess I'm having trouble seeing why your shift lever wouldn't work after tapping the other link on the other side? Just trying to understand.
    Rich
    Red Bluff, Ca
    Put me down for the shift rod and bracket. Rick(drdracing)
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Possibly interested in a column spacer.
    San Jose, CA
    Definitely in for the column spacer. I'm going to try using the long island-style mount of the FFR shifter first before I think about the K-tuned.
    Ok I see!! Tnx for that.
    Then I'm in for the spacer.
    Senior Member Triathletedave's Avatar
    Calgary
    Ok, I now understand the value of the steering spacer. I would be in for 1 as well.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Suisun City, CA
    I'm down for the steering column spacer and shifter arm.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    Tucson, AZ
    In for the spacer, shift rod arm, and maybe the cable bracket ( what benefit does the cable bracket actually provide? )
    Jan 2012
    Spacer for me.
    rori's Avatar
    Tulsa, OK
    Quote Originally Posted by Goldwing View Post
    I don't think the fork selector cable will be the problem; The bracket would be for the push/pull cable. The mounting point for the end of that cable is moved forward 40mm. The mounting point for the cable sheath would need to be moved forward also.
    Quote Originally Posted by bompus View Post
    This piece is completely optional. You have to modify the FFR bracket when using a k-tuned shifter. You have to further modify it when using my shift arm. My bracket will completely eliminate the FFR supplied bracket. You will use my bracket along with the bracket provided with the k-tuned shifter. As an added benefit I am correcting the geometry so that the cable is mounted in parallel with the shift rod for the most efficient operation.
    Encinitas, CA
    Hey RoRi, you seem to have gotten a pretty good response to your parts . Enough to convince you to sign up to be a vendor? (I hope)
    Junior Member Outwest's Avatar
    Nov 2012
    Definately interested in all of them, nice looking parts.
    Nov 2012
    Medina, OH
    Ah, I think I see now. I just got to this step in my build and starting to understand it. I'd have to look at the FFR cable sheath bracket more closely, but could your shift lever work with FFR's setup if one were to redrill holes to mount the cable sheath bracket 40 mm forward? Or, and this may be the same thing, use the rear most hole in the forward tranny bolt location, then drill a new rear hole? Though, a reversed machining might line up better for the fork selector.
    Rich
    rori's Avatar
    Tulsa, OK
    Yes, I ordered 15 steering column spacers today. They are 22 business days out. I will order shift arms tomorrow. I will sign up as a vendor when the parts arrive and I start asking for money.
    This is exactly how you would modify it for use with the k-tuned shifter after you cut off the mount for the fork selector cable. The problem with doing this using the stock FFR shifter is that you would also be moving the mount for the fork selector cable forward 40mm. If someone wants to be the guinea pig for that product and has the $$$ up front for a one-off part then send me a PM and I think I have an idea how we can make it happen and hopefully make them available for everyone. Otherwise I am not really interested in pursuing that avenue myself as it would require designing and testing parts that I can't test myself.
    rori's Avatar
    Tulsa, OK
    This is how the FFR supplied bracket is modified after cutting it down for the K-tuned shifter cables and moving it forward for the aluminum shift arm:
    This is the bracket that I came up with:
    Mounted with the supplied bracket from Waynes K-tuned kit:
    RoRi, please put AZPete on the list for both the steering column bracket and the shifter bracket. I just ordered Wayne's K-Tuned shifter because it's just too cool not to have and your mod will make it work better and look better. Please take my money!
    Pete
    Senior Member metros's Avatar
    NoVA
    I'd also like to get on the list for the steering column spacer, shift bracket and shifter arm.
    Exeter R.I
    Quote Originally Posted by metros View Post
    I would also want a column spacer asap, cool item
    Tallahassee, Florida
    I would like to get on the list for the steering column spacer when it becomes available. Just message me how you want to be paid.
    south-central CT
    It would be nice if you could re-do that big clunky bracket. I wonder how short a throw you can have? Does the bottom hole work without making for too much effort at the shifter? Could this area get "condensed"? It could all be tight to the housing if a bellcrank were employed.
    NoVA
    Updates? Are you thinking you have enough interest to make it worth your time/effort?
    rori's Avatar
    Tulsa, OK
    Yes, updates are in the first post below the pictures. Shift arms and Steering Column spacers have been ordered. Push/pull brackets will be ordered this week; they don't take as long to make. I should have all three parts in stock around the middle of this month.
    NoVA
    Excellent - sorry I missed the initial updates in OP.
    Senior Member TahoeTim's Avatar
    Mar 2014
    Lake Tahoe
    Agree 100%. stack the two cables with a single bracket, add a small platform and a bellcrank to the rear plate. the whole arm could be flipped down if the bellcrank was hooked up to reverse the throw. simple. i guess i'll have to try it when my kit arrives in August...
    Suisun City, CA
    Might as well add me for the push/pull bracket, as well. Make it a trio!
    Finished: NEVER!
