Results 1 to 22 of 22
Thread: FFR visit: Of Soft Top, Wipers, and Tank Mods
    Senior Member cmcintyre's Avatar
    Danbury, CT
    Had a chance to drop by and see the new Soft Top. Very well made, an homage to the complex tops of old English cars, so certainly not a push button affair! But, hey, its a Roadster, right.
    Good head room, (I’m 6”1”) but this seat is low and much of my height is in my legs. We put the windows in, some design changes might be happening there as they were difficult to fit at the front near the mirrors. Kind of a fiddle to open the door with them in. Hardtop not being developed right now. I’m putting in a HMSL, it will be visible on the roll bar with the top installed.
    Some other info from Jim S and Joe S....
    Wipers “just about done”. Hood will be modified at base of windshield, trim piece provided, access panel that is now there for the master cylinders will change, too.
    -Trunk is next, don’t plan on a different than stock exhaust if you want the trunk.
    -I picked up padded door panels, padded dash to be delivered. New option, 299.00. Only visible on the order page, not the parts catalog.
    The picture of the left seat forward edge shows it 3 inches further back than the right. This is made possible by a cutout to the top left of the gas tank, which will be available. Jim says do not install rear firewall yet if you are going this route. He also said tank supplier is very slow.
    Still a somewhat “Italian” driving position, the (optional, smaller) steering wheel kind of high. Tilting the wheel down obscures the top of the gauges. I think I will lower and shorten the steering column, but this is a very personal thing.
    " That which is rightly done, however humble, is noble." Sir Henry Royce
    SN 46 In the building 10/4/13.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Thanks a bunch. I'm quickly getting the sense I need to rethink my seating plan, unfortunately.
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
    About the wipers, any word if it will or not use any part of the donor?
    About the padded door panels and dash, any word on when we can get those and if it's 300 for the set or just the dash?
    Senior Member AZPete's Avatar
    Also, thanks a bunch. I like what I see of the top and look forward to buying it as soon as I get the body panels mounted. And the wiper kit. I'm glad FFR decided to go with a high-quality top rather than a leaky cheapie.
    And, maybe the padded door panels and padded dash. Oh no, my budget just slipped into the shredder.
    Danbury, CT
    Yes, the wipers use donor parts.
    The 299 covers panels and the dash, give em a call, the dash is not in yet.
    I think these were among the first padded door liners, I just walked in at the right time….
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Freeport, ME
    "access panel that is now there for the master cylinders will change, too."
    What access panel?
    Dan
    Danbury, CT
    First I heard of it too. An answer to the access problem, one answer being the remote reservoir kit (Mike Everson?).
    Wasn't installed even in the demo car, so just a discussion.
    The proposed factory change is to cut a twelve inch wide slot the height of the lower vertical portion of the windshield frame,
    left side, and cover it with an access panel. On the upper edge of that panel is a section with rubber tubing acting as additional support
    for the back edge of the hood.
    Does that make sense?
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Senior Member Doowop's Avatar
    Denver, CO
    holly crap that top is ugly. Glad I'm building an R!
    Quote Originally Posted by cmcintyre View Post
    Oh crap, I'll have to spend hours removing rust from the donor wiper parts, then. lolllllllll
    the dash is BO'd.
    lollllllllllllllll
    I'll try to get pictures.
    Freeport, ME
    The proposed factory change is to cut a six inch wide slot the height of the lower vertical portion of the windshield frame,
    yes, makes perfect sense. I was thinking of a full width drip rail with a rubber seal
    Dan
    Danbury, CT
    I decided to include that rear view of the car since it was the worst I could find.
    ….And I think it looks funky cool from that angle and great from any other!
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Jan 2012
    Do you have pics of the padded panels and dash?
    Danbury, CT
    Here ya go. Hope you can see the surface texture. They're not real deep plush, more a thick leatherette material on the solid plastic panel.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    I don't think that is a covering. I think it is molded into the plastic.
    Check the edges and let us know.
    Danbury, CT
    Close inspection of the edges (can't get a picture) has two distinct layers, the plastic base structure being about .09" and the textured covering material about .06". Hope that helps.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Danbury, CT
    duplicate post
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    anderson
    the door panel tool looks like it has been textured an etching process we used at work on interior parts that were injected molded
    Apr 2014
    More info on wipers?
    Quote Originally Posted by ruckus racing View Post
    Will re-use some of Sub parts, don't know which ones, will not be ready for month-end (April). Don't know the price, will be an option at order (not included int he based kit's price) or after order if you prefer to buy later or have already bought the kit.
    Apr 2014
    Ok. Good thing I wont be ordering mine for a while
    anderson
    there is a good video on you tube showing someone installing the conv top option
    makes me think about buying one .Does anyone know if are they all black?
    kerry
    Senior Member Aloha818's Avatar
    Waikiki
    Quote Originally Posted by indiana818 View Post
    kerry
    Jay at FFR told me only black.
    "In wine there is wisdom, in beer there is strength, in water there is bacteria."
    818 (Chassis #34) Delivered 9/25/2013, First start 3/2/2014, First drive 4/5/2014, Registered 8/28/2015, First Dyno 3/18/2016, First SCCA event 4/3/2016, First car show HIN Honolulu 4/23/2016
