Results 1 to 10 of 10
Thread: Radiator Supports, Zero Decibel Motorsports
    Mechie3's Avatar
    Indianapolis
    Parts are cut, tumbled, ready to go, and $8 cheaper than originally estimated
    Zero Decibel Motorsports Radiator Supports
    What:
    Upper radiator support made from aluminum. Factory rubber radiator support fits snugly into the bracket for perfect fitment with your radiator.
    Why:
    FFR's setup reuses the stock stamped steel supports cut in half and rotated 180deg. It's functional, but doesn't look too pretty. If you need to raise your radiator to clear the steering rack bellows the top of the radiator is no longer planar to the mounting surface on the front subframe. The steel pieces don't work as well if the radiator is much higher that the frame. When you remove your hood, these are the first pieces people are going to see.
    Cost:
    $30.
    Shipping
    Cheapest is the $5.80 flat rate box. The coolant bracket, ABS plates, carbon fiber plates, and the radiator plate can all fit in one flate rate box.
    Includes
    2 laser cut aluminum brackets
    2 machined aluminum standoffs
    2 stainless steel bolts (fits FFR supplied rivnuts)
    *Side Note:
    Customers will need to measure actual height from top of radiator to top of subframe. Actual length needed will be supplied to ensure proper fitment.
    Pictures:
    (rubber insert not included, use part from donor)
    Installed prototype uses flat head screws, final version uses button head screws
    Check out my new website!
    Suisun City, CA
    Craig,
    If we give you those requested measurements, are you adding in the factor for the thickness of the bushing? Or do you need to know the distance from the top of the radiator support to the middle section of the bushing?
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    Mechie3's Avatar
    Indianapolis
    I will compensate. Makes it easier.
    Suisun City, CA
    Cool. I'm @ .520".
    Payment sent! Do you still have my mailing address from last time?
    Finished: NEVER!
    Mechie3's Avatar
    Indianapolis
    I do. I have a spreadsheet I keep all that stuff on so I don't go crazy. I'll try to get the standoffs machined today so I can ship it tonight or tomorrow.
    Thanks!
    Apr 2014
    Very nice... keeping in mind for future
    Senior Member Triathletedave's Avatar
    Calgary
    Craig, do you offer a spacer set for the bottom of the radiator as well, or is Rori the only person doing that? So far my search has only resulted in bottom spacers available from Rori, and the top spacers from yourself. I'll continue searching though.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Mechie3's Avatar
    Indianapolis
    I made my own bottom spacers for my car. Rori is making bottom spacers to sell to others. For things like this I don't see a need to compete directly with other people if I'm not providing something that someone elses part does.
    Rori's part is also cammed. I noted my radiator didn't fit quite perfectly. The Cam system will let you adjust for wider/narrower spacing.
    Calgary
    Aha, that is exactly what I needed to know. I'll need two sets of uppers from you, and two sets of downers (whoops, lowers) from Rori to balance it out. Good to know. Thanks!
    TriguyDave
    818 noobie builder
    Calgary, Alberta
    Mechie3's Avatar
    Indianapolis
    10 more sets now in stock.
