0
0
Mine has a brass colored bracket attached to the cable about midway. The out sheath of the cable seems like it is too short but the actual cable seems like it is too long when attached to the clutch quadrant and the bell house housing. It is mounted where it will currently conflict with the header and have no idea where that bracket would mount other than under the square tube perhaps. Where did you order your cable?
