Results 1 to 2 of 2
Thread: Radiator Drain Plug Placement
    Jericho, NY
    Does anybody know why FFR installs the radiator with the drain plug at the top instead of the bottom? Is this normal placement or is it upside down for a reason?
    The FFR roadster radiator has a petcock at the bottom of the passenger side tank for draining and another at the top of the driver's side tank to use as an air bleed when filling the system. It's not "upside down"
