Blitzkrieg
I like the idea but getting the tank into the car is a problem. What if you made a tank that was triangle and a knotch cut out for the steering rack? Like 12" tall should be around 10gallons. Make it slip in from the top and sit on the frame.
I actually started with that idea, but the volume was just too small (more like 6-7 gallons, if I recall). I'll calculate it again for reference and post. I'm in CA for work at the moment, so it will have to wait until later this week or the weekend.
Also, sliding in/mounting from the bottom is better because in order to do so from the top you'd need to remove the windshield (it obscures a very large part of that triangular entry space).
